Old 05-28-2010, 10:27 PM
jreichen's Avatar
jreichen jreichen is offline
Plugin: Jetty Web Server 2.0
Version 2.0 of the Jetty Web Server plugin is now available in SageTV v7's plugin repository. It can be installed and configured from the Plugin Manager in the SageTV UI. The Jetty wiki has information about installing and configuring the plugin. Please note there are different pages for SageTV v6 and v7.
Upgrades: For questions related to the upgrading of Jetty from SageTV v6 to SageTV v7, please continue to use the existing thread.
Developers: If you have a web application, please take a look at the updated wiki page with information on how to customize your application's appearance on the new web applications page delivered with Jetty (screenshot above).
What's New: Version 2.0 adds several new features. Some of these include:
  • Support for the SageTV v7 Plugin Manager
    • Restart the web server without restarting SageTV
    • Configure primary user and password, HTTP port, HTTPS port, UPnP router configuration, and log level from SageTV's UI
  • Built-in web application for viewing all web applications currently installed, whether from the plugin manager or manually. To access it go to http://<server>:<port>/apps. Note that the links to the Web UI and Mobile Web UI aren't quite correct and the application names on your server may be different from the screenshot until each app is updated to support this feature.
Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun.
Extender: STP-HD300, Harmony 550 Remote,
Netgear MCA1001 Ethernet over Coax.
SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client
, Java 1.6.
Plugins: Jetty, Nielm's Web Server, Mobile Web Interface.
Old 05-29-2010, 01:33 AM
GKusnick's Avatar
GKusnick GKusnick is offline
Installing this upgrade seemed to delete *.jsp from my existing webapps (Web Server, Mobile Web Server, and SageAlert). To get them working again after the upgrade I had to manually stop the service, delete the deployments, and restart the service to force a redeploy.
Much as I like these plugins, I'm sorry to have to say this has been pretty typical of my experience with Jetty so far under V7. Almost anything I do in the way of installing or upgrading Jetty plugins breaks something that then requires manual intervention and multiple restarts to fix.
-- Greg
Old 05-29-2010, 04:57 AM
Peter_h Peter_h is offline
I also tried installing this and it is not working. It gives the following error page.
Error 404 - Not Found.
No context on this server matched or handled this request.
Contexts known to this server are:
* / ---> org.mortbay.jetty.handler.ContextHandler@1ce5421{/,file:/C:/Program%20Files/SageTV/SageTV/jetty/static}
* /sage ---> org.mortbay.jetty.webapp.WebAppContext@af88e3{/sage,C:\Program Files\SageTV\SageTV\jetty/webapps/nielm_sagewebserver.war}
* /sre ---> org.mortbay.jetty.webapp.WebAppContext@1a42493{/sre,C:\Program Files\SageTV\SageTV\jetty/webapps/sre.war}
* /bmt ---> org.mortbay.jetty.webapp.WebAppContext@15d3d12{/bmt,C:\Program Files\SageTV\SageTV\jetty/webapps/bmt.war}
* /sjq ---> org.mortbay.jetty.webapp.WebAppContext@ad8a09{/sjq,C:\Program Files\SageTV\SageTV\jetty/webapps/sjq.war}
* /apps ---> org.mortbay.jetty.webapp.WebAppContext@1415d6c{/apps,C:\Program Files\SageTV\SageTV\jetty/webapps/apps.war}
* /sagealert ---> org.mortbay.jetty.webapp.WebAppContext@5c978a{/sagealert,C:\Program Files\SageTV\SageTV\jetty/webapps/SageAlert.war}
I have both SJQ and the Web Server installed and working.
Old 05-29-2010, 08:00 AM
jreichen's Avatar
That's what Jetty prints when there's no path in the URL. Try http://<server>:<port>/apps.
, Java 1.6.
Old 05-29-2010, 11:33 AM
Ok, that works, thanks. Sorry, I didn't see that listed anywhere in the first post.
Can I customze what the links say? Also, my web interface link just shows up as "sage". It doesn't say "SageTV Web Interface" like your setup.
Old 05-29-2010, 01:14 PM
alfi33 alfi33 is offline
When I go to http://<server>:<port>/apps, I get a page that looks like this.
Directory: /apps/
SageLogo256small.png 15084 bytes May 24, 2010 9:22:48 PM
apps.css 2067 bytes May 24, 2010 9:22:48 PM
favicon.ico 2238 bytes May 24, 2010 9:22:48 PM
I am able to get to the apps by using the url for each individual app. Any idea why the built-in web application start page doesn't work for me?
Server: SageTV v9 on unRAID Docker; i5-2400; 16GB RAM; 9TB storage array; SiliconDust HDHR3
Client: Windows10; Intel Core2Duo; 4GB RAM; NVIDIA GeForce GT 1030
Client: NVIDIA ShieldTV
Client: Fire TV Stick 4K
Old 05-29-2010, 01:42 PM
titanium titanium is offline
I have the same exact problem
Old 05-29-2010, 02:34 PM
lotusvball's Avatar
lotusvball lotusvball is offline
everything works fine for me. Thanks.
Intel Core Duo 2.5mhz, 2gb RAM
Windows Home Server, Sage 7 beta
2 Hauppauge PVR-250, 1 PVR-500 MCE
1 HDHomeRun
4TB Storage, GB Network
2 MVPs, 1 HD100 & 1 HD300
Old 05-29-2010, 04:01 PM
GKusnick's Avatar
OK, I seem to have a repeatable scenario in which restarting Jetty (using the button on its plugin configuration page) hoses all my webapps.
Attached are two directory listings of the contents of my jetty\webapps tree. Before the reset, with all apps working, the tree contains 1715 files. After the reset, the tree contains 70 files, and (not surprisingly) all the apps are broken (including Jetty's own "apps" app).
All I did in between was restart Jetty. I did not change any WARs that would have entailed redeployment.
I have Jetty logging set to Verbose and have included a copy of sagetv_0.txt, but I'm not seeing anything in there that would account for this behavior.
As I noted earlier, getting back to a working state after this requires stopping the service and manually deleting the deployments.
If there's any further experimentation I can do or information I can gather to help debug this, let me know.
-- Greg
Old 05-29-2010, 08:03 PM
jreichen's Avatar
Sometimes developers make assumptions that others know as much about their code as they do I updated the first post.
The app developer can change it but users can't. Mine is different than what you see because I changed it on my setup to test it. That will be included in the next update for the web UI. If devs don't customize it then it will be the context path of the app (i.e. bmt, sre, sjq, sage, etc).
, Java 1.6.
Old 05-29-2010, 08:04 PM
jreichen's Avatar
You're having the same problem GKusnick is talking about.
, Java 1.6.
Old 05-29-2010, 08:07 PM
jreichen's Avatar
That's strange. I'm suspecting it only happens on Windows so I would expect you to have the same problem. I don't know what OS everyone is using but I see you're on WHS so maybe that's why
, Java 1.6.
Old 05-29-2010, 08:21 PM
I thought I was experiencing a similar issue as greg because when I clicked the on the sagem app it just saw a directory listing... then I realized that needed to drill down to "m" to get the home page. Maybe you could add "m/home.jsp" to the welcome pages in the web.xml.
I'm on linux and upgraded jetty without issue. So, maybe it's a windows thing.
Old 05-29-2010, 08:23 PM
jreichen's Avatar
Thanks Greg. I've been thinking about this and I think it's the Windows file-locking issue. When Jetty stops a web app it tries to clean up the temp folder. Any file with static content (.css, .jpg, etc) is locked but .jsp files are not. That's why the jsps are missing when the web app is started again. Since the folder already exists when the web app is started, Jetty will not try to extract the war again.
I'm not sure why sometimes it shows up as a 404 error and other times as a 503 error. Or why it seems to be happening much more frequently in SageTV v7.
I was able to create a Windows installation and recreate the issue so that helps a lot. I have a few things to try, hopefully one of those will give us a good resolution.
FYI I'm also getting reports of the same problem over in the Mobile Web UI for v7 thread.
, Java 1.6.
Old 05-29-2010, 08:27 PM
jreichen's Avatar
I just updated the OP with that shortly before you posted. The context xml needs to be updated for web apps that need more in their URL than just the context path. That's part of what is on the dev wiki page.
Looks like we cross-posted...
, Java 1.6.
Old 05-30-2010, 08:51 PM
darcilicious's Avatar
Just another "me too" post of sorts.
I'm getting the same issue after having installed the new/beta SageAlert. The Mobile App and regular Web Interface still both work fine after updating Jetty (did that first) but as soon as I installed SageAlert (did that second), the /apps/ stopped working and SageAlert comes up as 503 Service not available.
Let me know if there's any additional info I can provide / help with. Thanks so much for all this -- it really helps to make SageTV a superior PVR solution!
Old 05-30-2010, 09:38 PM
GKusnick's Avatar
I've found a workaround, which is to change the tempDirectory in the context file from /webapps/apps to /webapps/apps/work. This apparently tells Jetty not to delete the deployment on shutdown, so the apps still work after a Jetty restart.
I'll still have to manually delete the deployments when I want to force a redeploy, but for now that's better than having the apps break every time I cycle the service.
This workaround works for Niel's webserver and SageAlert. It did not work for the mobile web app without some extra fiddling, because that app apparently has the deployment path hard-coded in menu.jsp. (I'll make a note of that in the Mobile Web UI thread as well.)
-- Greg
Old 05-30-2010, 11:23 PM
OK, the "apps" page was working for me. However, after installing SRE, I now get the same "problem" page as everyone else is reporting.
Old 05-31-2010, 09:46 AM
RandyJohnson RandyJohnson is offline
when i type in http://192.168.1.209:8080/apps and after entering the user/password I get the following error dump:
Any idea what I might be missing?
Thanks in advance...
Randy
HTTP ERROR 500
Problem accessing /apps/. Reason:
    /index.jsp(16,62) PWC6188: The absolute uri: http://java.sun.com/jsp/jstl/core cannot be resolved in either web.xml or the jar files deployed with this application
Caused by:
org.apache.jasper.JasperException: /index.jsp(16,62) PWC6188: The absolute uri: http://java.sun.com/jsp/jstl/core cannot be resolved in either web.xml or the jar files deployed with this application
	at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:89)
	at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:375)
	at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:169)
	at org.apache.jasper.compiler.TagLibraryInfoImpl.generateTLDLocation(TagLibraryInfoImpl.java:433)
	at org.apache.jasper.compiler.TagLibraryInfoImpl.<init>(TagLibraryInfoImpl.java:238)
	at org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:498)
	at org.apache.jasper.compiler.Parser.parseDirective(Parser.java:578)
	at org.apache.jasper.compiler.Parser.parseElements(Parser.java:1642)
	at org.apache.jasper.compiler.Parser.parse(Parser.java:181)
	at org.apache.jasper.compiler.ParserController.doParse(ParserController.java:239)
	at org.apache.jasper.compiler.ParserController.parse(ParserController.java:140)
	at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:199)
	at org.apache.jasper.compiler.Compiler.compile(Compiler.java:435)
	at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:608)
	at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:360)
	at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:486)
	at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:380)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
	at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
	at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:389)
	at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
	at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
	at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
	at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417)
	at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:334)
	at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
	at org.mortbay.jetty.servlet.DefaultServlet.doGet(DefaultServlet.java:493)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1157)
	at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
	at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:131)
	at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1148)
	at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:387)
	at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
	at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
	at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
	at org.mortbay.jetty.handler.rewrite.RewriteHandler.handle(RewriteHandler.java:230)
	at org.mortbay.jetty.Server.handle(Server.java:326)
	at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:534)
	at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:864)
	at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:539)
	at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
	at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
	at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
	at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:520)
Old 05-31-2010, 10:30 AM
Brent94Z Brent94Z is offline
I got this all working but had to do some "extra" stuff.
First, I know I updated the plugin but then didn't try anything so not sure when/where the problems came about but here is what I noticed that might help you troubleshoot some of these problems...
When I went into my installed plugins I had several that were "Failed" and all appeared to be related to Jetty. I just did a complete reload of my entire system so wasn't sure if this is what broke it so wanted to check the settings. Under Jetty there was no longer a "configure" button??? I could reset it but not configure it? So, I decided to just uninstall all the web related stuff and Jetty. I then re-installed Jetty and it was showing as "Installed" but I still had no configure button. If I would exit Sage then restart and go back into the plugins, it would again tell me that Jetty "Failed". I uninstalled and reinstalled the Jetty plugin a couple times with the same results. I finally decided to just delete EVERY plugin in every tab on the plugins page (even all the Library plugins).
After I had every plugin removed, I reinstalled the Jetty plugin. This indicated it worked but it didn't untill I exited Sage and then went back to the Jetty plugin. I finally had the "Configure" button back! I configured it to my settings, installed the web app and mobile web app and both are working as well as the "apps" page you talk about above.
I'm no expert but to me it seems like the "Uninstall" button for Jetty doesn't remove enough "stuff". Mine only worked after I manually uninstalled the library files. Also, after installation of "Jetty", Sage needed to be restarted but the plugin install never asked me to do this... I had to restart manually.
Also, what took me for a bit of a loop and not sure if this changed or I just changed the way I input it but when configuring the password for Jetty, I used my keyboard and entered a 4 digit number. I could have swore this is the way I did this last week when I first set this up but maybe not??? Anyway, from a different computer I couldn't get into it... I knew it was at least kinda working because the password box popped up but it wouldn't take my password! On a whim, I remembered seeing some letters pop up when I was entering the numbers so re-entered the password from my HTPC and it worked so I took note of the LETTERS that popped up when I was entering the numbers. I tried these and they worked from my remote computer. I tried to change my password using the remote and same thing happened. I'm pretty certain I didn't press the "6" key like four times just to get the number "6" for a password so I think this changed as well and is something to be aware of. Might be obvious to "texters" but I didn't really pay much attention when entering the password and didn't at first notice that when hitting "6" on the remote or keyboard, it really isn't "6". LOL
Thanks for the hard work. Just wanted to post what I did to get it working. Thanks!
Plugin: SageTV Web Interface V2 for Jetty jreichen SageTV Customizations 256 02-09-2014 08:05 AM
Plugin: Jetty Starter 1.6 jreichen SageTV Customizations 122 09-07-2012 06:48 PM
error message with web server plugin edgley SageTV Customizations 3 01-15-2006 11:32 AM
Sage Web Server and existing web server compatibilty? Brent94Z SageTV Customizations 6 01-18-2005 11:29 AM
