Old 07-13-2010, 01:46 PM
hughinboston hughinboston is offline
Lost Sage TV Menus on my MVP
Hi all;
I have a Hauppauge MVP player that I've been using successfully with my Sage TV setup for about 2 years. Yesterday, the PC that Sage runs on crashed and when it came back up and I rebooted the MVP I got the old MVP menus on the TV - not the Sage ones. Yuk. I tried a few things to see if I could figure out what setting got un-done in the PC crash but can't. Does anyone know how the MVP knows to pull the Sage menu system from that PC? I'm hoping to avoid an uninstall and re-install of the Sage system.
Thanks in advance...
-Hugh
Old 07-13-2010, 05:26 PM
Is the setting for Sage to "talk" to extenders turned on?
Old 07-14-2010, 12:42 PM
Paul;
Yup, I think so. In Setup --> Detailed Setup --> Server, Media Extender and Placeshifter server is set to "Enabled". And I've checked and Sage sees a valid "Media Extender for MVP" license.
Thanks for any ideas...
-Hugh
Old 07-14-2010, 01:05 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Make sure the Hauppauge MVP server software is not installed on your Sage server (or on any other computer on your LAN) since that will prevent Sage from serving the MVP clients.
Other than that, just make sure your network is operating correctly and that your MVP has a valid IP address on the same subnet as your Sage server. If your server has more than one NIC/IP address, make sure the one on the MVP subnet has priority.
-- Greg
Old 07-14-2010, 01:24 PM
The MVP software is installed (has been for the last 2 years) but those 2 services are set to the "Disabled" state and do not run.
The subnets are all good. The MVP is set to connect to the correct PC on the network (the one running Sage).
I also tried to do a "Repair" of Sage in Windows Add/Remove Programs. No joy.
The MVP is still getting stuck at "Contacting MediaMVP Bootserver".
It's as though the Sage server is no longer listening at the correct TCP or UDP port on the PC.
Thanks for the ideas. If nothing else pans out I'll just have to bite the bullet and uninstall and reinstall Sage. I was just hoping to avoid that.
-Hugh
Old 07-14-2010, 01:28 PM
GKusnick's Avatar
Do you have a firewall on the server that could be blocking those ports?
-- Greg
Old 07-14-2010, 01:35 PM
Nope, wide open. And if I do start the MVP services, the MVP boots into the MVP software just fine and I can watch a video. So it just seems to be a setting somwhere in the Sage config or perhaps the registry that got corrupted. I think a re-install is in order.
-Hugh
Old 07-14-2010, 01:51 PM
GKusnick's Avatar
But is the server listening on the correct NIC? You said "subnets", plural.
-- Greg
menu, mvp
Double menus on MVP (SageMC) smousie SageMC Custom Interface 2 01-23-2008 12:15 PM
Two-tone menus lost in Sage 6 Sagebrush SageTV Software 2 05-03-2007 09:17 AM
Sluggish menus on MVP ben_gb SageTV Media Extender 0 07-12-2006 10:06 AM
Malore menus slow to load on MVP Gaurav SageTV Customizations 0 03-07-2006 02:21 PM
Lost my mvp license BBCritical SageTV Media Extender 3 02-22-2006 11:32 AM
