Old 05-06-2004, 02:05 AM
Stuttering playback or pauses in playback
anyone experincing anything like this (Stuttering playback or pauses in playback)?
I am experiencing stuttering on the server with pauses tried every codec I can think of
I am experiencing pauses on the client with also trying alot of codecs
I am not having any 30 sec pauses or anything like that
playback is much better than .017 for the clients
but just 1.2 pauses
furthermore I just wanted to add that I get audio and video stuttering when changing channels
Well if anyone else experiencing problems please post
Frey has already said in the forums he believes there are no outstanding problems but playback should be the biggest issue if there is a problem
smoother playback wihtout pauses is desired before v2 goes retail
Old 05-06-2004, 07:12 AM
Mike Young Mike Young is offline
We were disccusing this on another thread, but that problem, I belive occurs only on the client.
Currious what record rate you are using...I have found that I cannot use 5.6gb without stutter on client, but my server was fine.
Other than that, the causes I have found for stutter like you describe in order :
1. Other software or services loaded (ZoneAlarm, Nortons or other utilities)
2. Fragmented or disorganized disk (use 64K blocks)
3. Disk errors (run chkdsk /r
4 Bios settings
5. Wierd Network settings
mike/
Old 05-06-2004, 08:10 AM
Cabalsan's Avatar
Cabalsan Cabalsan is offline
I also get a stutter but it only happens after coming out of a 10 Sec Fast Forward.
I am using SageTVRC2 (2.0.17). Have upgraded from 1.3.8 to 2.0.11 to 2.0.14 to 2.0.17. This problem was not in the earlier versions. Something changed between 14 & 17 as nothing has changed on my system at all - no driver/window updates & no added softare.
-Cab
*edit* Oh I use 2Gb/hr recording mode only on my HTPC.
