Old 12-05-2010, 11:53 AM
uberpixel uberpixel is offline
Question Broken install - can't reinstall - SMM API Failed
I had SMM running fine on my WHS box a few weeks back but I started noticing some weird behaviour - like not being able to play newly added movies and the movie posters showing up on the main menu screen even when I wasn't in SMM.
So... I thought I'd uninstall and reinstall.
Now I can't install SMM. When I try to install the plugin, the SMM API says it Failed and SMM is Disabled.
I've tried installing the latest MyMovies for WHS, and I've tried stopping the SageTV service and deleting the datafiles then fresh reinstall.
I get the same result each time. Is there something else I should try?
Any help? I can't seem to generate a log for SMM since I can't install it.
uberpixel
{Server} | i5-3330S | Z77X-UD5H | 8gb DDR3 | Windows 10 Pro |
{Tuners} | (1) HDHomerun (OTA) | (1) HDHomerun Prime + OpenDCT on Comcast |
{Client} | (2) HD300 Extenders | (1) PC Client | Mi Box Android Client | FireTV Stick |
Old 12-05-2010, 07:46 PM
teq's Avatar
teq teq is offline
What has worked for me in a similar situation is to delete the SMM application (NOT the API!). This should result in the SMM API listed as active. Then reinstall the SMM application.
Hope this helps.
Cheers,
teq
Old 12-05-2010, 11:10 PM
Hope this helps.
Cheers,
teq
That worked.
SMM API V1.200 Keeps Failing foleyma Sage My Movies 11 10-17-2010 10:56 PM
SMM API install keeps failing craigap Sage My Movies 25 10-06-2010 08:42 AM
Still having API Failed problems with version 1.15 FlyingDoc Sage My Movies 2 09-18-2010 11:25 AM
upgrade failed during license entry, reinstall? Dekard SageTV Linux 1 11-15-2006 01:25 PM
RC3 Reinstall Failed Mike Young SageTV Beta Test Software 3 05-07-2004 09:50 PM
