SageTV Canada SageTV and SageTV Recorder Users from Canada - This forum is for you to post about specific issues using SageTV software in Canada. |
PVR/HD Box
Have installed a PVR/HD Box adjacent to TV, concealed in cupboard and have to open door to use remote, is there something that I could do to extend the range? Thanks if anyone has an ideal!
here is a link to what I use http://www.amazon.com/RFS200-PowerPa...U/ref=pd_cp_e_
I have had this setup for several years and works perfectly. I never have to open the cabinet where my box is located. Even though it's a little costly, I can use it to control all of my AV equipment. ![]() Last edited by iumgrad; 01-03-2012 at 10:13 AM. |
Personally, I'd go with an RF-based remote control, like the Harmony line from Logitech.
Server: XP, SuperMicro X9SAE-V, i7 3770T, Thermalright Archon SB-E, 32GB Corsair DDR3, 2 x IBM M1015, Corsair HX1000W PSU, CoolerMaster CM Storm Stryker case Storage: 2 x Addonics 5-in-3 3.5" bays, 1 x Addonics 4-in-1 2.5" bay, 24TB Client: Windows 7 64-bit, Foxconn G9657MA-8EKRS2H, Core2Duo E6600, Zalman CNPS7500, 2GB Corsair, 320GB, HIS ATI 4650, Antec Fusion Tuners: 2 x HD-PVR (HTTP tuning), 2 x HDHR, USB-UIRT Software: SageTV 7 |
The problem is that you pay a huge premium for the RF versions of the Harmony remotes - about a $150 premium to go from the Harmony One to the Harmony 900.
Harmony does have something called the link for $99. This allows you to use apps on an Android or Apple device to control your components. The only issue with that is that I personally prefer real button to touchscreen remotes, particularly if you do a lot of skipping - as I do. But why would you ever watch LiveTV if you have Sage? Then you can use IP control of Sage extenders or PC clients.
Tags |
pvr, remote, signal |
