SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
Bitstreaming DTS-HD with 24 bit depth tracks
I've noticed that a couple of my recent m2ts files from blu-rays have issues with bitstreaming the DTS-HD audio on the HD300, in the form of no audio or choppy audio. Two examples are X-Men: First Class and Bridesmaids. All my older rips still play fine. When I compare the files in mediainfo the one difference I see is that the files that play fine have a bit depth of 16 while the problem files have a bit depth of 24. Anyone having similar issues and is this a limitation of the HD300?
Jim SageTV7, Windows 7, Comcast, HDHR Prime(SageDCT), HD300 |
I've also been suffering with the same problem, so far it's happened to me with X-Men First Class, Harry Potter 7 pt2, The Fighter and The Social Network, I hadn't gotten around to looking at the problem but now you've mentioned it the one thing they all have in common is 24bit DTS-HD audio and AVC video stream (High@L4.1).
I don't think it's specifically the 24bit audio as Fast and Furious is also 24bit DTS-HD and that plays fine but it's video is VC-1 instead of AVC. I've got some other Blu-Ray's in the same format so I'll give them a go and see if they have the same problem and I can also try another HD300.
Server: Win7 64bit; i5 2500; 32GB ram; Blackgold BGT3595; 18TB + 120GB SSD; Edgestore DAS401T; DVBLink; Oscam; Omnikey 3121 Lounge Client: HD300; Yamaha RX-V765 connected to 55" Furrion 1080p LCD; Logitech Harmony One remote Kitchen: HD300 32" LCD, Bed 1: HD300 - 40" LCD, Bed 2: HD300 - 24" LCD, Bed 3: HD300 - 22" LCD |
Try installing the latest non-beta firmware for the HD300. It fixed the exact problem as you for me.
Waiting for Sage 8. ![]() |
Great
The higher res GUI was enabled in the first beta after the last release firmware, so you could try that and see if you have the same problem: http://forums.sagetv.com/forums/show...77&postcount=7
and yes, it is frustrating... ![]()
Just checking back in on this one to see if anyone has found a workaround. I just tried using different containers like mkv and blu ray folder structure with no improvement. Next up will be rewinding firmware versions.
The workaround is to use beta firmware 20110124-2. No problems with DTS-MA and support for high resolution menus. You have to manually install it, the easiest way is to install the firmware from a usb drive after renaming the files to "stp300.bin" and "stp300.ver". The HD300 manual explains how to do a manual firmware install.
FYI, DTS-MA is broken in firmwares 20110217-2 and later. |
For anyone searching, here is the link to the 20110124-2 firmware:
http://forums.sagetv.com/forums/show...1&postcount=14 |
Thank You user community! I ran into this "bug" a while ago and
Dismissed it as a bad rip. But I saw it on a couple other rips as well yesterday. I spent a couple hours playing with cables, network config, playing from USB.. nothing worked.. And I even saw it on another movie I swear I had watched already.. So I found this thread.. I reverted the firmware to the latest suggested here and BAM the audio works now... At least on the one file I tested... I guess I blindly upgrade to the latest beta firmware on both my HD300s without seeing if there was an issue or not! Thanks again!! Jim Last edited by jbuszkie; 02-19-2013 at 09:27 AM. |
For those of us using the HD300 as an extender (not in standalone mode), using the beta firmware version 20110124-2 obviously benefits us in that DTS-HD Master Audio works. Anyone know if there is a downside to using the older beta firmware version (20110124-2), rather than either of the two newer versions? Here's what the change logs have to say about the newer versions:
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, 2 x Hauppauge WinTV-HVR-2250 Dual TV Tuner Boards Clients: Multiple HD300 Extenders Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
I finally got around to doing this last night and now I actually have sound on my 24 bit DTS-HD tracks! I think being able to hear the audio on these newer releases would far out weigh whatever minor fixes the later versions incorporated.
Anyone have a link about how to manually revert back to an earlier firmware on the 300's? I've seen it but now can't find it. I also thought I had some bad rips, but now think this is happening to me as well....
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, WD Green 2 TB x 1 and WD Red 6 TB x 2 for DVD/Bluray Rips, Music, Home Movies, etc., Sage 9.1.8.770, HDPVR x 2, BellTV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver Clients: PC Client x 2, HD-300 x 4 (1 Using Netgear MoCA Coax Bridges), Placeshifter x 1 |
You can find instructions in the HD300 manual on how to manually revert firmware. You can find the manual Here
But basically... Configuration Reset Procedure If none of the other troubleshooting suggestions have solved the problem, then you can try this Configuration Reset Procedure: 1. Turn the player off by unplugging the power cable. 2. Press the Back button on the remote and continue holding it as you plug the power cable back in. Continue holding the Back button until the Service Menu appears on the TV. 3. Note that if nothing is visible on the TV when using the HDMI or Component connections, connect the HD Theater to your TV using the Composite connection instead. 4. Choose a reset option: o Factory Reset – Reload the firmware and reset the configuration. See below for more information regarding reloading the firmware. o Reload Firmware – Only reload the firmware. o Config Reset / Restore / Backup – Offers options to reset the configuration, restore the configuration previously backed up to an attached USB storage device, or save the current configuration to an attached USB storage device 5. After the reset procedure, check the above troubleshooting tips again. When reloading the firmware, three options will be available: From SageTV Server – Load the firmware from the SageTV installation folder on a PC connected to your local network. The firmware files should be placed in the SageTV installation folder where SageTV.exe is located. From Internet – Load the firmware by automatically downloading the firmware files via an Internet connection. From USB – Load the firmware from an attached USB storage device. The firmware files should be placed in the root folder of the USB storage device. When choosing to load the firmware From SageTV Server or From USB, you will need to download the following firmware files and copy them to the locations specified above. (The firmware files are automatically downloaded and applied when using the From Internet option, so no separate download is needed for that option.) http://download.sage.tv/firmware/stp300.bin http://download.sage.tv/firmware/stp300.ver Those are the file names. Take the firmware you want and rename it to stp300.bin/ver Last edited by jbuszkie; 02-23-2013 at 08:34 AM. |
Ah thank you! Had it in my head that it was a forum post I saw it somewhere. Never thought of it actually being in the manual... ![]()
Lost the 7 like interface option on the HD-300 by going back that far, but that's ok, hardly ever use the extender in stand alone anyways. Tnx ![]()
I'm glad the beta firmware 20110124-2 is working well for everyone. I also wanted to mention that this firmware fixes a bug while playing FLAC files in the latest official release. The FLAC bug causes the audio to stop and the only fix I found was to reset the HD300.
So to summarize: Latest beta firmware = broken DTS-MA Latest official firmware = broken FLAC Firmware 20110124-2 = just right ![]() |
*necromancy!*
sorry to raise this from the dead, but this is awesome! i had switched my extender to plain HDMI bitstream years ago because the audio would always cut in/out and in doing so, Sage would just pass the core 5.1 to my AVR. Recently, I switched extenders from another room that still had the audio output to 1.3 bitstream and I was reminded of this sad fact that I couldn't get 7.1 sound. Thought to my self...hey, it's been years, I wonder if there has been any research on why this is? Downgraded to this beta (from the last beta) and no more drops on DTS-MA tracks (I'm using exclusively as an extender)! |
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
Well that was 2013... and I can't remember where I left my keys 30 minutes ago... ![]() IIRC, I think I used the Sage server method - following the instructions to put the .bin and .ver files in the same directory as sage.exe ...
HD300 HBR (HDMI 1.3) bitstreaming | stanger89 | SageTV Media Extender | 11 | 01-30-2012 12:10 PM |
ffdshow HD audio bitstreaming | panteragstk | Hardware Support | 0 | 03-20-2010 02:13 PM |
Stop Sage complaining about color depth? | elaw | SageTV Software | 5 | 06-07-2007 08:03 AM |
SageTV color depth message | nathanm | SageTV Studio | 3 | 11-10-2006 05:04 PM |
How do I clear the bit-depth nag at startup? | AndyS | SageTV Software | 2 | 11-06-2005 11:49 AM |
