Linux 64bit MiniClient (issues with JTux on 64bit)
I did get MiniClient recompiled and I updated it with 64bit jogl libraries, but, when I start the miniclient and select a server it dies immediatly in the JTux code...
Sat 8/15 6:47:29.819 Connected to gfx server Sat 8/15 6:47:29.921 Testing to see if server can do a pull mode streaming connection... Sat 8/15 6:47:29.922 Loaded Type size error: sizeof(jint) < sizeof(size_t) Type size error: sizeof(jint) < sizeof(ssize_t) Type size error: sizeof(jint) < sizeof(ino_t) Type size error: sizeof(jint) < sizeof(nlink_t) Type size error: sizeof(jint) < sizeof(blksize_t) Type size error: sizeof(jint) < sizeof(nfds_t) Type size error: sizeof(jint) < sizeof(msgqnum_t) Type size error: sizeof(jint) < sizeof(msglen_t) Type size error: sizeof(int) < sizeof(ino_t) Jtux error: Java native types don't match POSIX/SUS types. Sat 8/15 6:47:29.923 Server can do a pull-mode streaming connection. Sat 8/15 6:47:29.926 Max screen size=java.awt.Dimension[width=1920,height=1200] Sat 8/15 6:47:29.926 Error w/ Media Thread: java.net.SocketException: Socket closed Sat 8/15 6:47:29.926 Error w/ GFX Thread: java.net.SocketException: Socket is closed java.net.SocketException: Socket closed Quote:
JNIEXPORT void JNICALL Java_jtux_UUtil_check_1type_1sizes(JNIEnv *env, jclass obj) The code does an extensive job checking sizes, and I'm not sure just commented it out is the right approach ![]() Code:
if (sizeof(jlong) < sizeof(long)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(long)\n"); } if (sizeof(jlong) < sizeof(void *)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(void *)\n"); } if (sizeof(jint) < sizeof(int)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(int)\n"); } if (sizeof(jshort) < sizeof(short)) { ok = false; fprintf(stderr, "Type size error: sizeof(jshort) < sizeof(short)\n"); } if (sizeof(jlong) < sizeof(clock_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(clock_t)\n"); } if (sizeof(jlong) < sizeof(gid_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(gid_t)\n"); } if (sizeof(jlong) < sizeof(pid_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(pid_t)\n"); } if (sizeof(jlong) < sizeof(uid_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(uid_t)\n"); } if (sizeof(jlong) < sizeof(rlim_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(rlim_t)\n"); } if (sizeof(jlong) < sizeof(time_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(time_t)\n"); } if (sizeof(jlong) < sizeof(suseconds_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(suseconds_t)\n"); } if (sizeof(jlong) < sizeof(useconds_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(useconds_t)\n"); } if (sizeof(jlong) < sizeof(off_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(off_t)\n"); } if (sizeof(jlong) < sizeof(fsfilcnt_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(fsfilcnt_t)\n"); } if (sizeof(jlong) < sizeof(fsblkcnt_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(fsblkcnt_t)\n"); } if (sizeof(jint) < sizeof(size_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(size_t)\n"); } if (sizeof(jint) < sizeof(ssize_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(ssize_t)\n"); } if (sizeof(jint) < sizeof(mode_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(mode_t)\n"); } if (sizeof(jlong) < sizeof(dev_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(dev_t)\n"); } if (sizeof(jint) < sizeof(ino_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(ino_t)\n"); } if (sizeof(jint) < sizeof(nlink_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(nlink_t)\n"); } if (sizeof(jint) < sizeof(blksize_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(blksize_t)\n"); } if (sizeof(jlong) < sizeof(blkcnt_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(blkcnt_t)\n"); } if (sizeof(jint) < sizeof(nfds_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(nfds_t)\n"); } if (sizeof(jlong) < sizeof(key_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(key_t)\n"); } if (sizeof(jint) < sizeof(msgqnum_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(msgqnum_t)\n"); } if (sizeof(jint) < sizeof(msglen_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(msglen_t)\n"); } if (sizeof(jlong) < sizeof(mqd_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jlong) < sizeof(mqd_t)\n"); } if (sizeof(jint) < sizeof(socklen_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(socklen_t)\n"); } if (sizeof(jint) < sizeof(sa_family_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(sa_family_t)\n"); } if (sizeof(jshort) < sizeof(in_port_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jshort) < sizeof(in_port_t)\n"); } if (sizeof(jint) < sizeof(in_addr_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(jint) < sizeof(in_addr_t)\n"); } /* Assuming C ints (not only jints) are at least 32-bits, because of the int argument to field_ctoj_int. */ if (sizeof(int) < sizeof(in_addr_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(int) < sizeof(in_addr_t)\n"); } if (sizeof(int) < sizeof(ino_t)) { ok = false; fprintf(stderr, "Type size error: sizeof(int) < sizeof(ino_t)\n"); } if (!ok) setup_throw_errno(env, ENOSYS); Quote:
It appears that on 64bit systems jint 32bits and size_t is 64bits, whereas on 32bit systems they are the same size. This is odd, since the C spec states that size_t should be size of unsigned int, which it would expect to be 4 as well. Code:
sizeof(jint): 4, sizeof(size_t): 8 sizeof(int): 4, sizeof(uint): 4 ![]()
MrD reported the same thing over on your "Build SageTV (Linux Specific) + GitHub primer" thread. He hadn't replaced any 32-bit libraries so you might double check that on your installation.
Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun. Extender: STP-HD300, Harmony 550 Remote, Netgear MCA1001 Ethernet over Coax. SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client, Java 1.6. Plugins: Jetty, Nielm's Web Server, Mobile Web Interface. |
char is always 1 byte short is always 2 bytes long is always 4 bytes long long is always 8 bytes int must be at least the size of a short, so can be 2/4/8 bytes depending on compiler/architecture. Eddy
Automatic Power Off | Squeezeslave | DVB-S Importer | DVB Decrypter & Card Client | Tuner Preroll Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit. ~ Elbert Hubbard |
Yeah, probably not. |
Again this isn't a problem with the sizeof(int) or sizeof(size_t), per se, but rather that JTux made some assumptions that sizeof(jint) == sizeof(size_t).
jint is NOT a std C type but a java type.
The good news is that on the server, JTux is not used very often, but on the Miniclient it's used quite a bit.
Out of curiosity, what is the motivator/target use for compiling a 64 bit miniclient?
From what I can tell, jtux was written about 10-12 years ago so maybe it wasn't originally 64-bit compatible. There are a couple of "forks" (the original wasn't on github) but they both have the same check for jint/size_t:
https://github.com/BanjoPicker/jtux https://github.com/swenson/jtux During some earlier searches I was doing, it looked like jint is always 32-bit, and size_t varies with the platform. However, jni_md.h defines jint as an int. To me that means it should also vary with the size of the platform. ![]()
if jtux is so old, should it maybe be considered obsolete and a new solution be found? What purposes is it used for in miniclient that couldn't be done with more agnostic java library calls?
JTux is also used on the server code, but doesn't appear to be used quite as extensively. Maybe Jeff will weigh in ![]()
I'm betting it was used as a stop gap to have better socket control than what java 1.4 offered. I'm guessing 1.6 has some better options available, and certainly better performance. I would think in miniclient, which by its function, is likely to be the most portable of the bits of code, we should stick to as much core java api's as possible, and avoid OS specific calls, if possible.
stuckless, I was looking at the JOGL upgrade and they changed a bunch of package and class names. For instance javax.media.opengl is now com.jogamp.opengl, and the GLPbuffer object no longer exists. That's as far as I got
![]() So far I've been working on the Linux builds and haven't needed a Java IDE. Looks like it's time to work on that. Jeff, any thoughts on the JOGL API changes?
Yeah, if you look at my build.gradle, you'll see I've been playing around with pulling in the updated JOGL... and yeah, there are lots of changes. It appears that there are more than just package name changes as well
![]() I tried all the 2.0x versions and they all have issues. So I think the version that sage is using is either a very old 2x RC or a 1x version.
So it should be fine to remove the jtux dependency altogether from the SageTV core. In the miniclient code, it looks like there's 2 things it was doing....both are because it needed to use Unix domain sockets rather than IP sockets. One of them is for LIRC integration...the other looks like its for shared memory access for video rendering. Quote:
Jeff, I noticed on my system that I was able to run the MiniClient without JOGL... so I'm guessing that it is selectively used? Is there some advantage to using JOGL over standard java implementation, which you've done as well?
Yeah, it defaults to 3D acceleration on by default:
else if ("true".equals(MiniClient.myProperties.getProperty("opengl", "true"))) { if (MiniClient.WINDOWS_OS) { myGfx = new DirectX9GFXCMD(this); } else { try { Class[] params = {this.getClass()}; Object[] args = {this}; java.lang.reflect.Constructor ctor = Class.forName("sage.miniclient.OpenGLGFXCMD").getConstructor(params); myGfx = (GFXCMD2) ctor.newInstance(args); } catch (Throwable t) { System.out.println("Error loading OpenGLGFXCMD class, reverting to default rendering:" + t); t.printStackTrace(); myGfx = new GFXCMD2(this); } } }
Side question related to jtux and 64bit. I'm considering pulling JTux because of the 64bit issues that I found. I could probably spend the time trying to see if there really is a reason why JTux is very explicit about its checks, and I have done some work in that direction, but I now leaning towards just using https://github.com/kohlschutter/junixsocket They support linux/mac/arm and they have 32bit and 64bit packages. The other nice thing is that you only need to include the jar and the natives-jar in the classpath and it will auto-resolve/load the system dependant .so files. Any thoughts, objections? This doesn't cover the usb portion, but you said that wasn't used, so I was going to remove it... or find a recent libusb for java.
xp 64bit & HVR-2250 | vikingisson | Hardware Support | 13 | 06-07-2010 10:05 PM |
Anyone running 64bit with SageTV on Linux? | bcjenkins | SageTV Linux | 74 | 07-05-2009 12:59 AM |
Having trouble setting up Placeshifter client on Linux FC9 64bit | mooseca | SageTV Linux | 0 | 03-14-2009 01:29 PM |
Any advantage to using XP 64bit | rdefino | General Discussion | 4 | 10-15-2006 01:47 AM |
To 64bit or not to 64bit | teknubic | Hardware Support | 19 | 07-25-2006 10:57 AM |
