Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Phoenix 3.0
Phoenix 3.0 This forum is for discussing the user-created Phoenix 3.0 custom interface for SageTV.
Old 05-21-2017, 02:50 PM
UserCategory Filtering
So I was playing with PClassic, and noticed that the UI has a UserCategory filter option, but it comes up empty. Any reason the UserCategories aren't populating to be selected in that list?
Old 05-22-2017, 12:16 PM
bialio's Avatar
bialio bialio is offline
Where is this UserCategory filter at? It's been a while since my P2 days so I'll have to remember what it IS first
Then I can try and answer the question.
btl.
PHOENIX 3 is here!
Old 05-22-2017, 12:39 PM
From any view (like the default TV view), hit options, then choose Filter... Second from the bottom is UserCategory.
Old 05-22-2017, 12:45 PM
Looks like its getting the list of filters direct from Phoenix_umb_getFilters, so it may be something that was added to the api after Phoenix 2, and was never working.
Actually, it looks like it's actually just trying to set the filter, but sort of getting stuck at an empty MediaBrowser branch. It seems to do this for any of the filters that require options (Genre and UserCategory). All the simply Boolean filters (MissingTV, ReRun, Watched, etc) work fine, and return right back to a filtered list.
Old 05-22-2017, 12:50 PM
bialio's Avatar
Yeah, the filtering in the Media Browser was always only supported for 'simple' filters (i.e. boolean). There were tags added in the vfs file to distinguish these. I bet that when UserCategory got added that tag got copy/pasted over inadvertently. After a quick browse of the default vfs file I see a few others that likely won't work...
btl.
PHOENIX 3 is here!
Old 05-22-2017, 12:54 PM
Not a huge deal for me, at least.. As I said, I was only just playing with it. Most of my views will end up being made in a vfs xml file anyway, and used in PLite if at all I'm guessing.
balun and harmonic filtering profit Hardware Support 0 01-31-2013 07:53 PM
Help with Filtering MediaFile[] joshuad156 SageTV Studio 6 04-27-2011 02:45 PM
Filtering out vs filtering in Spectrum SageTV Beta Test Software 9 09-29-2010 11:34 AM
Sorting and Filtering Videos? can3gxw SageTV Beta Test Software 0 05-28-2010 02:28 AM
Pre-filtering jeffoz1 Hardware Support 3 06-18-2003 07:46 PM
