Old 08-09-2017, 11:54 AM
PeteCress's Avatar
v9 PlaceShifter Install: 0x800700e8: Failed to wait for child to connect to pipe.
Windows 10.
Am I the only one?
[062C:08B8][2017-08-09T13:43:41]i001: Burn v3.10.2.2516, Windows v10.0 (Build 15063: Service Pack 0), path: C:\Users\Kolon\AppData\Local\Temp\{1AE6E44C-CAB4-4687-B2D7-4092413CA614}\.cr\SageTVPlaceshifterSetup_9.1.1.651.exe
[062C:08B8][2017-08-09T13:43:41]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]SageTV'
[062C:08B8][2017-08-09T13:43:41]i000: Initializing string variable 'SageInstallerVersion' to value '1.013'
[062C:08B8][2017-08-09T13:43:41]i009: Command Line: '-burn.clean.room=C:\Users\Kolon\Desktop\SageTVPlaceshifterSetup_9.1.1.651.exe'
[062C:08B8][2017-08-09T13:43:41]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Kolon\Desktop\SageTVPlaceshifterSetup_9.1.1.651.exe'
[062C:08B8][2017-08-09T13:43:41]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Kolon\Desktop\'
[062C:08B8][2017-08-09T13:43:41]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Kolon\AppData\Local\Temp\SageTV_Placeshifter_20170809134341.log'
[062C:08B8][2017-08-09T13:43:41]i000: Setting string variable 'WixBundleName' to value 'SageTV Placeshifter'
[062C:08B8][2017-08-09T13:43:41]i000: Setting string variable 'WixBundleManufacturer' to value 'TheSageTVAuthors'
[062C:27A4][2017-08-09T13:43:41]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[062C:27A4][2017-08-09T13:43:41]i000: Setting version variable 'WixBundleFileVersion' to value '9.1.1.651'
[062C:08B8][2017-08-09T13:43:41]i100: Detect begin, 4 packages
[062C:08B8][2017-08-09T13:43:41]i052: Condition 'VersionNT64' evaluates to true.
[062C:08B8][2017-08-09T13:43:41]i000: Setting numeric variable 'vc10x86Exists' to value 1
[062C:08B8][2017-08-09T13:43:41]i000: Setting version variable 'vc10x86Version' to value '10.0.40219.325'
[062C:08B8][2017-08-09T13:43:41]i052: Condition 'NOT VersionNT64' evaluates to false.
[062C:08B8][2017-08-09T13:43:41]i000: Setting numeric variable 'vc14x86Exists' to value 1
[062C:08B8][2017-08-09T13:43:41]i000: Setting version variable 'vc14x86Version' to value '14.0.24215.1'
[062C:08B8][2017-08-09T13:43:41]i000: Setting string variable 'JavaCurrentVersion' to value '1.8'
[062C:08B8][2017-08-09T13:43:41]i052: Condition 'JavaCurrentVersion AND (JavaCurrentVersion >= v1.7)' evaluates to true.
[062C:08B8][2017-08-09T13:43:41]i052: Condition 'vc10x86Exists AND vc10x86Version >= v10.0.30000' evaluates to true.
[062C:08B8][2017-08-09T13:43:41]i052: Condition 'vc14x86Exists AND vc14x86Version >= v14.0.23026' evaluates to true.
[062C:08B8][2017-08-09T13:43:41]i101: Detected package: Java7Runtime, state: Present, cached: None
[062C:08B8][2017-08-09T13:43:41]i101: Detected package: vc100, state: Present, cached: None
[062C:08B8][2017-08-09T13:43:41]i101: Detected package: vc140, state: Present, cached: None
[062C:08B8][2017-08-09T13:43:41]i101: Detected package: SageTVPlaceshifterSetupMSI, state: Absent, cached: None
[062C:08B8][2017-08-09T13:43:41]i199: Detect complete, result: 0x0
[062C:27A4][2017-08-09T13:43:51]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[062C:08B8][2017-08-09T13:43:51]i200: Plan begin, 4 packages, action: Install
[062C:08B8][2017-08-09T13:43:51]w321: Skipping dependency registration on package with no dependency providers: Java7Runtime
[062C:08B8][2017-08-09T13:43:51]w321: Skipping dependency registration on package with no dependency providers: vc100
[062C:08B8][2017-08-09T13:43:51]w321: Skipping dependency registration on package with no dependency providers: vc140
[062C:08B8][2017-08-09T13:43:51]i000: Setting string variable 'WixBundleRollbackLog_SageTVPlaceshifterSetupMSI' to value 'C:\Users\Kolon\AppData\Local\Temp\SageTV_Placeshifter_20170809134341_000_SageTVPlaceshifterSetupMSI_rollback.log'
[062C:08B8][2017-08-09T13:43:51]i000: Setting string variable 'WixBundleLog_SageTVPlaceshifterSetupMSI' to value 'C:\Users\Kolon\AppData\Local\Temp\SageTV_Placeshifter_20170809134341_000_SageTVPlaceshifterSetupMSI.log'
[062C:08B8][2017-08-09T13:43:51]i201: Planned package: Java7Runtime, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[062C:08B8][2017-08-09T13:43:51]i201: Planned package: vc100, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[062C:08B8][2017-08-09T13:43:51]i201: Planned package: vc140, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[062C:08B8][2017-08-09T13:43:51]i201: Planned package: SageTVPlaceshifterSetupMSI, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[062C:08B8][2017-08-09T13:43:51]i299: Plan complete, result: 0x0
[062C:08B8][2017-08-09T13:43:51]i300: Apply begin
[062C:08B8][2017-08-09T13:43:51]i010: Launching elevated engine process.
[062C:08B8][2017-08-09T13:44:03]i011: Launched elevated engine process.
[062C:08B8][2017-08-09T13:44:03]e000: Error 0x800700e8: Failed to wait for child to connect to pipe.
[062C:08B8][2017-08-09T13:44:03]e000: Error 0x800700e8: Failed to connect to elevated child process.
[062C:08B8][2017-08-09T13:44:03]e000: Error 0x800700e8: Failed to actually elevate.
[062C:08B8][2017-08-09T13:44:03]e000: Error 0x800700e8: Failed to elevate.
[062C:08B8][2017-08-09T13:44:03]i399: Apply complete, result: 0x800700e8, restart: None, ba requested restart:  No
Program Source: OTA antenna
Old 08-09-2017, 08:23 PM
jusjoken jusjoken is offline
My guess...a permissions issue on execution. Try running the installer as admin
k
Old 08-09-2017, 09:20 PM
Placeshifter works fine for me under W10 and I don't use Administrator accounts. I can't remember if I ran the installer as Administrator, though. That is a good thing to try. Microsoft recommends that you don't run as Administrator, but things even from "big" names like nVidia and Oracle don't always install right, (and e.g. nVidia graphic drivers and JAVA--although the latter seems fixed now--you have to log in as an Administrator and not just "Run As...")
Of course all that is moot if your account is an Administrator...
Old 08-10-2017, 05:02 AM
The installer error is failed to elevate hence my guess on permissions.
I have never had an issue installing Placeshifter so not sure what else to suggest.
k
Old 08-10-2017, 03:09 PM
PeteCress's Avatar
Solved: It was the Anti-Virus
I invoked Avast's "Turn everything off for 10 minutes" option, and the install went A-OK.
I think it was something with Avast's file scan during the install.
Jetty download failed, BMT won't install farscapesg1 Batch Metadata Tools 2 11-28-2011 09:50 AM
Broken install - can't reinstall - SMM API Failed uberpixel Sage My Movies 2 12-05-2010 11:10 PM
ComskipPlayback plugin install failed hogburgs SageTV v7 Customizations 3 08-29-2010 07:51 PM
Failed to connect from remote location but connects at home craigap SageTV Placeshifter 24 01-02-2008 03:33 PM
Loading Preview. Please wait, and wait and wait... dshields Hardware Support 7 05-10-2006 09:55 PM
