Old 10-13-2017, 06:45 PM
checkbin checkbin is offline
Updating Schedules Direct Login Password
I've been searching the forums but can't seem to find an answer for this. I have EPG set up with Schedules Direct (SD) which I set up long ago and has been working fine. I now want to update my SD account in SageTV after updating it with SD. But I can't find out where to update it short of removing the EPG source completely and adding it again. Can anyone tell me where I can simply update the login password? Thanks in advance.
Old 10-13-2017, 07:55 PM
wnjj wnjj is online now
I think you can delete the 'sdauth' file in the Sage directory to get it to ask again.
Old 10-14-2017, 07:33 PM
EnterNoEscape's Avatar
You can do that or you can just select the current lineup on the capture device as if you were going to change it, then select Use Schedules Direct Guide Data with this Source, then Change Username and Password. After you enter your new password, you can back the whole way out and nothing will be changed, but your password.
Old 10-18-2017, 06:25 PM
Awesome. Thanks very much to both of you.
Old 11-15-2018, 12:23 AM
miloj miloj is offline
Actually, once expired it just gives you a pop-up saying so, and ok button to dismiss it. There's no way through the GUI to change the user/password in this case - a bit of a bug.
But wnjj's workaround works if you know about it.
Old 11-15-2018, 07:56 PM
I would like to see a log demonstrating this issue. What you're saying doesn't logically make sense. You should see the dialog offering to change your password before it even attempts to authenticate to your account if you followed the steps I described.
Schedules Direct - How Far Out Does it Get? mike1961 SageTV EPG Service 7 06-17-2017 11:31 AM
Using Schedules Direct in UK jamesdisco SageTV United Kingdom 28 02-06-2017 11:54 AM
Sage login and password pvr599 SageTV Software 6 04-01-2014 08:10 PM
Password and login - not! tvmaster2 SageTV Placeshifter 4 11-05-2009 10:10 PM
