SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
Stuttering on MP4 files
I usually run ffmpeg to compress the huge mpg files i get from the HDHR OTA on Sagetv.
Occasionally the HD200, mibox or Nvidia Shield stutters playing them back. To rule out the network I used a very long cat 5 cable with cross over plug to go direct from the server to the extender as a test. I had the same stuttering occasionally. Which according to the WAF, it is way too often if it ever happens. ![]() I have the same issues using WiFi to a mibox in my RV. I am looking at all the Video Renderer, Decoder Filters and other setting in the video/audio settings for the sage server and wonder if any of those affect playing the mp4 videos on the external devices like the HD200/300 This screen shot shows the current settings.. -Bill
Home DVR: SageTV v9.2.2(64) i3-6100 3.7ghz, 4GB RAM, Win10 Pro, 3 small fast SSD +1@6TB WD Blue, 1 Quad HDHR, ( OTA Winegard HD8200U, CM4221HD), 1@ STP-HD200, 1@ Nvidia Shield , 1 @ Nvidia Shield new round, 70", 55" & 40" Sony's RV DVR: 2@SageTV v9.2.2, NUC8i5BEK 16GB, SS980Pro NVMe, 5TB Passport, 1@olderNUC, 2 Dual HDHR, , Winegard BatWing, 40", 32", 28" Sony's, Max Transit |
Are you sure that the stuttering isn't in the original MPEG-2 source file? Does the stuttering always happen at the same spot in the file?
It does not always occur in the same place, also, if I pause for a bit the stutter goes away for a bit like it buffered some of the file and then it runs out again and stutters again.
Strange - it sounds like a network problem but you have kind of ruled that out with a direct connection. Have you ensured that you get decent speeds across the network - even with a direct connection? I have a NIC go bad on a motherboard on my Sage server and it fell back to 10Mbps
The nic on the sagetv server is fast. I pull large files from it all the time and consistently get close to 100 megabyte speeds. (not mega bit) Not sure how it can be that fast on a gigabit link. There must be compression in the mix.
Maybe its the nic on the HD200 going bad. I will swap that out for a HD300 I have in the RV and see what happens. BTW, the settings that I asked about in the initial post have nothing to do with what happens on the hardware clients?? Thanks, Bill speedtest.JPG
Nope. Pretty much everything in that menu is for controlling local video playback on the Sage Server. There's not much to set on the Extenders, since most of the decoding is handled in hardware (you can't tell it which decoder to use for playback or whether to use hardware acceleration on the video card, etc.).
BTW - speed test is not really a good indication of whether your network hardware has issues. Problems with your NIC or Ethernet switch can cause packets to be lost or corrupted. Ethernet is very resilient so can resend lost packets. For something like file transfer, it's not a big deal if some packets arrive out of order, but real time video is much less forgiving.
Also, network troubles aren't the only thing that can cause stuttering playback and recordings. Problems with a hard disk (even if it's not the disk your video is stored on) are another likely culprit. And of course, over-burdened CPUs can cause similar problems as can memory problems. It's worth taking a look at the Windows error logs to see if it reports any issues.
HD100: Stuttering on playback - all files; Solved | brandypuff | SageTV Media Extender | 12 | 08-09-2009 10:25 AM |
sage.PlaybackException (-3,0x80070057) for DVD image files and WMA audio files | toby | SageTV Software | 3 | 05-02-2009 10:53 AM |
WMV HD files stuttering on the HD100 | infocus13 | SageTV Beta Test Software | 8 | 10-09-2008 12:09 PM |
Some Stuttering Observations... Make that Observations of Stuttering | Tahoe Girl | SageTV Placeshifter | 7 | 02-11-2007 07:39 PM |
Probably a widely discussed problem:STUTTERING, LiveTV stuttering:causes and remedies | Gemini1706 | SageTV Software | 6 | 08-24-2004 12:32 PM |
