Old 03-27-2018, 10:08 AM
daminc daminc is offline
sage remote cleaning
The last couple of years, I've been having problems with the remote actually working correctly with the box. Usually hit and miss pressing most buttons... Searched to figure out how to take apart the remote with no results. decided to tinker with it to clean the contacts, and found the mystery screw under the front sticker. With that removed its easy to pop the locking tabs under the rubber bumper along the bottom and sides.
Sprayed it all with cleaner, and it works like new again
Figured I'd post this since I found a few posts on not being able to take apart the remote
Old 03-27-2018, 01:25 PM
brandypuff brandypuff is offline
Thanks for the tip
I wondered how to take the remote apart. I have a couple that could stand cleaning as well.
- James M -
Server: Asus P5B Deluxe, 8GB, Core2 E6600 @2.4GHz, Windows 10 X64 Pro
Storage Internal: (1) 250GB, (2) 2TB, (1) 4TB
Storage External: Sans Digital 4-Bay eSATA Port Multiplier RAID Enclosure with (4) 4TB Drives
Capture Devices: HDHomerunXTEND, HDHomerunPrime
Clients: (1) STX-HD100 HD Media Extender, (3) HD200 HD Theatre, (1) HD300
Old 03-27-2018, 01:56 PM
MattHelm MattHelm is offline
You just cleaned the PCB, correct?
Anyone have to do anything the the rubber(?) buttons? If so, what worked?
Old 03-27-2018, 02:11 PM
Taddeusz Taddeusz is offline
You may need to get some conductive paint, like car defroster repair paint, to restore the conductivity of the underside of the buttons.
Old 03-27-2018, 02:16 PM
it looks like conductive mesh embedded in the rubber..
I have pics, but have to resize them to upload
Old 03-27-2018, 02:17 PM
I cleaned both the rubber pad and the board with electronic cleaner. The board looks like conductive paint
Old 03-27-2018, 02:24 PM
heres a few pics
Old 03-28-2018, 10:38 AM
i just checked my remote and don't see any screw on the front under the SageTV logo which is painted on the plastic. The Plastic flush so there in nothing under the logo. where is this mystery screw? Cab you post a picture?
- James M -
Old 03-28-2018, 01:42 PM
this is where my 3 were located
Old 03-28-2018, 01:44 PM
your remote doesn't have the decal like mine?
Old 03-28-2018, 03:36 PM
Instead of peeling up the decal, maybe drill/punch a small hole thru the decal where the screw hole is located?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i3-7100T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Old 03-28-2018, 04:41 PM
wnjj wnjj is offline
That's a great idea. Those decals don't look too happy to be peeled back.
Old 03-29-2018, 06:01 AM
no decal, solid piece front plate.
- James M -
Old 03-29-2018, 06:36 AM
HD200 remote = decal
HD300 remote = no decal, text painted directly on case
Maybe???
Old 03-29-2018, 07:34 AM
they possibly did away with that mystery screw....It seemed like overkill the way the case snaps together anyway.. My remote has a slot in the battery compartment, where I looked and saw a post where the mystery screw was located... I have an HD100, and two HD 200s
Old 03-12-2020, 08:59 AM
PeteCress's Avatar
I found the one near the bottom - as shown in the pic.
Where are the other 2?
Server: SageTV 7, Windows 7, Intel i7 @3.5GHz, 8 GB RAM, 80-gig SSD drive
Clients: HD200*4 over Cat5e Ethernet + Asus Zen running Client over WiFi-ac + 1 HD200 remote at another residence
Storage: NetGear Ultra-6 NAS 10 TB total w/dual redundancy. Plus (3) 2-tb local drives for RecordedTV.
Program Source: OTA antenna
Old 03-12-2020, 09:10 AM
do you need to peel off the rubber strip that wraps around the remote?
- James M -
Cleaning out old plugins Deano Gemstone for v7 15 10-16-2012 06:05 AM
Recordings cleaning up heffneil SageTV v7 Customizations 10 04-21-2011 11:28 AM
need help cleaning up server SageGk SageTV Software 0 12-05-2009 12:02 PM
Cleaning up Snow Help ToyMaster458 Hardware Support 4 11-22-2006 10:02 AM
Cleaning up Harddrive ascv General Discussion 2 04-01-2005 07:47 AM
