Old 11-10-2018, 10:10 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Forcing Refresh in PlugIn
Does anybody know of a way for a java General plugin to force the configuration settings menu to refresh? I want to update the information returned by the getConfigHelpText() method as the plugin runs a task in the background.
Old 11-10-2018, 11:46 AM
If you know the widget id from the STV, could you not use the WidgetAPI Refresh api?
Old 11-10-2018, 02:07 PM
tmiranda's Avatar
There is no Refresh API in WidgetAPI that I am aware of.
Old 11-11-2018, 04:55 AM
Sorry, it's in the Global API.
http://download.sage.tv/api/sage/api...va.lang.String)
Old 11-11-2018, 12:19 PM
tmiranda's Avatar
I'm pretty sure that won't work from the plugin because there is no active UI context.
Old 11-11-2018, 01:12 PM
You can get all the UI context names and just issue it for each of them.
Forcing type to TV by folder? mtncrux Batch Metadata Tools 2 01-03-2012 01:04 PM
Forcing Sage to use Quicktime sandor SageTV Mac Edition 4 01-05-2009 02:10 PM
Forcing a channel update tvmaster2 SageTV EPG Service 1 09-18-2006 05:34 AM
forcing 3 digit channel change alonpb SageTV Beta Test Software 2 04-20-2004 08:56 PM
Forcing an epg reload (xmltv) grot SageTV Beta Test Software 7 06-02-2003 03:54 PM
