Old 11-20-2018, 09:14 AM
dinki's Avatar
dinki dinki is offline
SageTV Mobile Web Interface installation broken
Hey guys.. Trying to get SageTV Mobile Web Interface installed but I'm getting an error when it tries to install the mediastreaming dependency:
Can someone tell me how I can get around this? I don't want to stream but am looking for a mobile friendly view of the web gui. Thanks
Intel Core i5-2500, 16GB RAM, OMV Linux 4.17, 3 TB of Data
SageTV 9 Docker, Open DCT Docker
Silicondust HDHomeRun Duo + Quatro
Sage Mini Client on Amazon Fire Sticks and Android TVs
Old 11-20-2018, 01:47 PM
I don't have an answer but just FYI the mobile interface doesn't work with Java 8 and up.
Old 11-20-2018, 01:59 PM
dinki's Avatar
Good to know. Thanks for sharing this. So nothing viewable on mobile?
Old 11-20-2018, 04:10 PM
KryptoNyte's Avatar
I suppose you could run the miniclient for Android and have the full GUI.
Old 11-20-2018, 06:49 PM
there used to be an android app (not the mini client) called phoenix remote i think. I used it up until i was forced to an iphone by my employer. i think it was called phoenix remote.
Old 11-20-2018, 09:19 PM
No, it just throws an error. If I recall it uses some construct that was depreciated. Pretty sure I posted about it somewhere on here.
I have Phoenix Remote, but it is for playback and not scheduling, (and really geared for LAN usage I believe). The only time I used it was to play things when on the LAN and the mini-client was not working. Now I use Plex for that.
The mini-client on a phone is also small. The (not ideal, but best I found) way to schedule recordings on the phone or check things is just use the regular web UI and pinch to zoom.
Old 11-21-2018, 11:54 AM
thomaszoo thomaszoo is offline
Maybe I'm looking at the wrong thing, but I'm pretty sure it works for me.
i5-6400, MSI B150M Micro ATX MB, 16GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 10 (64), HDHR Dual X2, Quatro and Prime, 5 x HD300 + 2 x HD100
Old 11-21-2018, 12:28 PM
Attachment 17079
Attachment 17080
Ah, yeah. Have you tried to do things in the interface though?
https://forums.sagetv.com/forums/sho...&postcount=375
Old 11-21-2018, 12:39 PM
OK, thanks. That clarifies it for me. So it looks like the guide is definitely broken (per the other thread and my own testing) and searches don't work. I typically only use it to see what has recorded, is recording or is scheduled to record. And to read any system messages. For these things it still works just fine, at least for me.
Old 11-21-2018, 01:46 PM
dinki's Avatar
Yeah, my goal was to be able to use it for searching and scheduling. So I guess this is a loss cause.
Someone should, still, update the xml file to not include this plugin as it cannot download the necessary files to install.
Old 01-22-2019, 07:16 PM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
I would still like to install this plug-in to use for browsing recordings. I'm trying to figure out how to install it manually, as I have located the zip file, etc.
Thanks in advance!
Server: Home-built i3-4170 3.7GHZ, 500GB SSD, 8GB DDR3, Win 10 64-bit, 4TB of drives for recording
SageTV: 9.2 - 64-Bit
Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels)
Client 1, 2, 3, and 4: HD200.
NAS: Synology DS211 4TB (Movie Storage)
Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in
Old 01-27-2019, 07:13 AM
I've republished talluscorp plugins (SageTCPServer and MediaStreaming), so this should now install.
https://forums.sagetv.com/forums/sho...487#post619487
Mobile Web Search Broken KarylFStein SageTV v9 Customizations 23 03-14-2019 09:31 PM
Plugin: Mobile Web Interface 1.2 jreichen SageTV Customizations 281 06-17-2011 02:20 PM
SageTV Mobile Web Interface Version 2.1.0 SteveD SageTV v7 Customizations 11 06-13-2011 08:05 PM
FAQ: Mobile Web Interface V2 iOS Streaming jreichen SageTV v7 Customizations 3 11-07-2010 08:28 PM
Wanted: Developer for Web Interface Mobile Brent SageTV Customizations 249 02-09-2009 11:21 PM
