Old 02-22-2020, 09:29 AM
SHS's Avatar
SHS SHS is offline
USB quadHD Linux Driver
Bard didn't have time to get PPA release ready hope in next few weeks but if your brave in compile your own kernel it is located here https://github.com/b-rad-NDi/media_t...uadhd.mxl692.a
Sorry I don't have no experience in kennel compiling
Be sure report any problem here https://github.com/b-rad-NDi/Ubuntu-...builder/issues
Old 02-26-2020, 03:17 AM
SHS's Avatar
SHS SHS is offline
Bard said
As long as you don't run ubuntu hwe 16.04 or ubuntu bionic 18.04 4.15.0 then the ppa should get your fully up and running now. The 4.15.0 releases will not build due to the way the build system depends on certain packages, and launchpad removed those packages...
sudo add-apt-repository ppa:b-rad/kernel+mediatree+hauppauge
sudo apt-get update
sudo apt-get install linux-mediatree
sudo apt-get install linux-firmware-hauppauge
Old 04-13-2020, 01:23 PM
Which kernels will properly auto update drivers etc? I am currently experimenting with ubuntu base to try to get better functioning from my hauppauge hardware. Mainline kernels don't seem to get any updates in a timely matter.
Old 04-13-2020, 01:35 PM
SHS's Avatar
SHS SHS is offline
Don't know I running PoP! OS
Hauppauge WinTV-quadHD SHS Hardware Support 188 12-26-2021 11:01 AM
WinTV-quadHD USB SHS Hardware Support 23 03-12-2020 05:31 PM
SageTV + hauppauge QuadHD + DVB-C fre Hardware Support 4 11-08-2019 11:48 PM
WinTV-quadHD Ghildebr Hardware Support 24 01-29-2017 11:19 AM
New nVidia Driver upgrade for Linux gplasky SageTV Linux 0 04-10-2006 09:34 AM
