Old 01-04-2021, 01:00 PM
graywolf's Avatar
graywolf graywolf is offline
How to display Date as MM/dd/YY (zero pad)
In Studio, I have:
DateFormat("MM/dd/yy", StartTime)
It is displaying dates like 12/1/20 and 1/3/21 but I want it to be 12/01/20 and 01/03/21
Per the API it says:
DateFormat
public java.lang.String DateFormat(java.lang.String Format,
java.lang.Object Date)
Returns a formatted date string for the specified Date.
Parameters:
Format - null if SageTV's default date format should be used, otherwise use a formatting string as specified in java.text.SimpleDateFormat
Date - either a java.util.Date object or a long which corresponds to the date
Returns:
the date formatted string
From my understanding, SimpleDateFormat is suppose to be displaying MM/dd/yy as 12/01/20, 01/03/21, etc
What am I missing?
Old 01-04-2021, 10:56 PM
wnjj wnjj is offline
I looked into the DateFormat code and there's special handling in there for localization:
// Replace M/d with the appropriate representation for this Locale
In the code (https://github.com/google/sagetv/blo...lity.java#L249), it uses a regular expression to match on M or MM followed by /, followed by d or dd and replaces it with a localized version using java.text.DateFormat.SHORT.
I don't claim to understand all of this completely but it's possible that what you are trying to do won't work.
Windows Installer
Old 01-05-2021, 07:01 AM
graywolf's Avatar
Thanks. That explains it.
Changing to MM-dd-yy works to have the padded zeros i.e. 12-01-20 and 01-03-21
Sorting based on released date and add to library date not working still Gustovier Diamond 35 03-15-2011 12:45 PM
How to Display Recordings by Recording Date & Original Air Date joe123 SageTV Customizations 25 02-16-2010 05:28 AM
Locale setting (date display) on HD200? MrFusion SageTV Media Extender 0 10-18-2009 08:06 AM
HD200 date/time display glitch troycheek SageTV Beta Test Software 6 05-24-2009 05:34 PM
SageTV display cutoff using secondary display chrishallowell SageTV Software 1 02-09-2008 08:44 AM
