Old 03-13-2021, 09:24 PM
elcid elcid is offline
SageTV V9 commercial processing
Hi.
I think this is dead but asking. Is commercial detection / processing no longer available in latest SageTV V9?
I had showanalyzer which worked pretty good but no longer supported.
Old 03-14-2021, 08:18 AM
ComSkip works fine for me. I have no reason to think it’s been removed. Do you have the ComSkip extension installed?
Old 03-14-2021, 08:21 AM
trk2 trk2 is online now
Comskip still works. If you are recording in h.264 you need to purchase the registered version of comskip.
Old 03-14-2021, 02:23 PM
jimcgreen jimcgreen is offline
Comskip stopped working for me on 3/11/21. When I look at the installed plugins The Commercial Detector plugin shows "Failed". Today I got an informational message that there was an update for Comskip Playback. I took the update and reloaded the UI. If I try to run Comskip on one of the shows recorded on 3/11/21 nothing happens. Commercial Detector still shows "Failed" in the list of installed plugins. Is there a log that will show me why it failed?
Old 03-14-2021, 07:26 PM
Do you have a registered version of Comskip? If so and you installed a newer version of the Comskip plugins then they only come with the plain version of Comskip that won't work on most newer recordings.
In my setup for Comskip I put the registered version in its own folder and point to it in the Comskip settings so that is the version that processes recordings.
That way I can install updated Comskip plugins and my registered version is still there. The updated versions don't seem to mess with Comskip settings so there is no need to "re" point it to your registered version.
That reminds me, I should see if there's a newer registered Comskip version than what I'm curently running.
Wayne Dunham
Old 03-14-2021, 08:10 PM
Where do I purchase it? Google does not show anything. Also once purchased how do I install it? I added it via the plugins and I see "run comskip" but when I run select it, nothing happens - probably waiting on the key?
Old 03-14-2021, 08:19 PM
You buy it from https://www.comskip.org/
Once you make the purchase you will get an email with a link to download the h264 version. Replace the existing free version of the comskip.exe file that SageTV downloaded with the newly purchased one.
You should be able to process h264 files now.
Old 03-15-2021, 12:19 PM
Read my previous message here. Put the registered version in its own folder outside of the normal Comskip folder. Then go into the Comskip settings and point Comskip to the registered version of Comskip rather than the default version.
The reason for this is that any time there is an update to the Comskip plugins it will overwrite whatever is in the Comskip folder with whatever the newest (NON registered) version of Comskip is.
By putting the registered version into its own folder any updates won't mess with your registered version. The update process doesn't alter your Comskip settings in the SageTV setup area so the updated plugin will still use our registered version to process our recordings.
Then any time you get an updated registered version you can just overwrite into the seperate registered version location. NOTE: thre is no automatic update to newer registered versions of Comskip you will have to check for new versions periodically and download/install them manually.
Wayne Dunham
Old 03-17-2021, 08:49 AM
sic0048 sic0048 is offline
Is there any reason to update Comskip?
I ask because I have the registered version and installed it years ago. I have never updated it, but it seems to work just fine. While I've never really thought about updating it, I also have the mindset of "if it's not broken, don't fix it."
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 03-17-2021, 09:22 AM
Are you sure you fit in here?
Old 03-17-2021, 10:21 AM
phelme's Avatar
phelme phelme is offline
I haven't checked in a while to see if it's still being updated myself. guess I should do that.
the big reason to keep it current is the author is/was maintaining the "bug" database of network logos to scan for to insert the transitions from commercial to show (purposely not saying "content," no sir).
Edit: if I'm not mistaken, looks like the last update was over a year ago:
comskip82_010_donators 2019-12-23 15:19 13M
Old 03-19-2021, 10:19 AM
I guess I have grown "wiser" in my old age. 10 years ago I was flashing everything - Android phones, automation stuff, updates, etc. Now I'm too lazy to do any of that.
SageTV v9 (64bit)
OpenDCT
Comskip Question - Avoid Processing Commercial Free Channels will SageTV v7 Customizations 3 10-10-2013 07:25 AM
SageTV as a commercial solution Target SageTV Software 11 05-21-2008 01:36 PM
Live Commercial Processing wrems SageMC Custom Interface 8 04-03-2008 08:28 PM
SageTV Setup question - offload processing power from my HTPC to my fileserver! matstars SageTV Software 8 11-07-2007 01:47 PM
Commercial processing not happening digitalgm SageTV Customizations 5 06-28-2005 08:06 AM
