Old 12-28-2021, 11:48 PM
jhkoenig's Avatar
jhkoenig jhkoenig is offline
SageTV Web Interface with V9 64bit points to 32bit directory
So I was amazed at how easy it was to upgrade Sage V9.2.6 from 32bit to 64bit! I installed 64bit Java 8, 64bit Open-DTC, and of course 64bit Sage server. To my delight, everything worked... except the Sage Web Interface plugin. When I try to access the web page, I get: HTTP ERROR: 503
Problem accessing /sage/Home. Reason:
SERVICE_UNAVAILABLE
If I go to the root of the URL (just "/" with nothing else) I see that the web server is looking at the 32bit Program Files directory (C:\Program Files (x86)\SageTV\SageTV\jetty/webapps/nielm_sagewebserver.war}) instead of the 64bit Program Files directory.
I have uninstalled and reinstalled the Jetty and the SageTV Web Interface plugins without any success.
Any idea what I am doing wrong? Thanks!
Win10@16GB RAM, 30TB Disk across 6 disks. 2 Prime tuner units
Sage v9 (64bit) using OpenDCT to control the Primes
2 HD-300s, an Android mini-client, and a Windows client
Old 12-29-2021, 06:16 AM
jusjoken jusjoken is offline
SERVICE_UNAVAILABLE
Did you copy your properties file from the 32 bit install?
I would look into the properties file and search for that path.
K
Old 12-29-2021, 11:29 AM
TGsell TGsell is offline
Same issue - Jetty Web Server plugin will not install properly with 64bit Sage 9.2 etc -- not sure where I lost it - perhaps the next version of Java, or 32 to 64 ? or? If anyone can advise how to get this working again I would appreciate it.
Old 12-29-2021, 12:08 PM
jhkoenig's Avatar
K
I think that you are right! I can see the the 32bit path numerous times in the properties file, so I will make changes during my next downtime window. That's one of my frustrations with plugins: they don't delete their entries in sage.properties when uninstalled, leading to an accumulation of dangerous junk in the file that can come back to haunt.
Old 12-29-2021, 09:59 PM
Can you provide more details and perhaps your SageTV log file so we can review the failure. I am working on the update to jetty and have installed the old version numerous times on 64 bit SageTV.
K
Old 12-29-2021, 10:28 PM
jhkoenig's Avatar
Everything works now! I edited the paths in sage.properties as recommended and things are great. Thanks for the advice.
Old 12-30-2021, 11:36 AM
Can you show the edit? I have not had 32bit Sage for a few years now but might be able to reconstruct since it would be nice to have the Web Interface again. thanks
Old 12-30-2021, 12:05 PM
jhkoenig's Avatar
I just shut down Sage, then searched the sage.properties file, searching for the string "(x86)" and removing it (plus the space before the open paren) so that the parameter now points to the 64bit equivalent. A bit scary (I did make a copy of the properties file just in case I did something stupid) but it all worked out great.
Old 12-30-2021, 02:28 PM
Thank you -- I will give it a try!
SageTV Plugins 64bit vs 32bit jvl711 SageTV Github Development 3 05-08-2020 07:56 AM
Vagrant files of 32bit and 64bit images that can be used for SageTV Linux Development stuckless SageTV Github Development 0 08-16-2015 01:43 PM
XP (32bit) to Win7 (64bit) with Sage 6.6.2.218? bellyman SageTV Software 1 12-07-2011 09:13 AM
Windows 7 64bit or WHS 32bit? nebulink General Discussion 20 03-08-2010 12:40 AM
64bit processors with 32bit OS Question Stuntman Hardware Support 8 09-08-2006 10:12 AM
