  #221
Old 03-25-2010, 11:33 AM
martinez036 martinez036 is offline
How?
Originally Posted by farmboy03 View Post
Serial control of my Motorolla DCT2244 is now working! I made the change to dct.reg this morning and it worked like a charm. Thanks for figuring this out! Once Sage TV 2.0 comes out I will finally have a real Tivo replacement.
I have a Motorola DCT2244 but I don`t seee the seria port. How can I install the DCT.exe? How did you do? Do I need a serial port or internally? Thanks for you help..
Old 05-05-2010, 12:26 AM
vhurst's Avatar
vhurst vhurst is offline
Originally Posted by Thron View Post
I have a Motorola 2224 connected to my system with a serial cable running Sage v5. When I test the serial port using the dct.exe (dcx xxx) it changes to the channel I want. When I try to setup the MultiDCTTuner Sage completely locks up. I have messed with it for over 2 days now and I cant figure it out.
I finally gave up and installed Sage v6 hoping this would solve the problem. Now when I select MultiDCTTuner Sage crashes and shuts down. I have logging enabled but it never gets to that point. Does anyone have any ideas?
For the time being I went back to using USB-UIRT to slowly change the channels.
I had the same problem. Just fix the logfile path in MultiDCTTuner.ini. This plugin was written so long ago, and the default Sage directory has changed. After the path correction, it still works great for Sage v6.6.2.
Setting up more than one DCT STB takes some more work though. Read the instructions carefully, and get familliar with the sage.properties file!
Intel Skulltrail D5400XS, Dual Quad Core Xeon L5420, Windows Server 2012 R2 on 200Gb partition, 32Gb RAM, 8x WD 2Tb RE4 RAID6 on LSI 9690SA-8I (DVD/Blu-Ray), 2x 4Tb HDDs (TV), Colossus, 2x HD-PVR, HDHR3 Prime, DirectTV STB, USB-UIRT, Sage v2 v3 v4 v5 v6 v7.1.9, Java v1.6 build 45, 3 Placeshifter licenses, and 3 HD-300's.
Plugins: Phoenix API, PlayOn For SageTV, Comskip Playback, YouTube, Nielm's Sage Utiities
Software: PlayOn, ComSkip Monitor, ComSkip
