| SageTV Placeshifter Discussion related to the SageTV Placeshifter application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the SageTV Placeshifter software application should be posted here. |
Run Placeshifter from USB Drive?
Is there a way of installing a "portable" version of the new placeshifter program? I'd like to add it to my portable utilities USB drive that I carry with me. Would be nice to be able to pop in the drive and use sage on any computer with an internet connection. If this is possible it would really make sage an ultimate entertainment product.
Thanks in advance, David |
Just unzip this: http://download.sage.tv/SageTVPlaceshifter.zip and put that on the USB drive. It'll require that Java is installed on the machine; but it'll work with even Java 1.3 so that's installed on almost everything out there.
You could try this: Placeshifter on USB KEY.
Edit: we must have been typing at the same time. - Andy
That's what I needed to hear. Thank you guys. Time for a day of upgrading in my future.....
PlaceShifter on a USB key ?
Now that I have used PlaceShifter both a home as an extender and this week for the first time travelling (woo hoo
), I'm hooked.I was wondering if anyone had tried/discussed placing a PlaceShifter client on a USB key to run directly from the USB key. It would allow the application to run directly off the USB key on any computer without installing the app on the computer being used. Excuse me if this is far more complicated than it appears, but I thought I would ask to see if anyone had tried it or given it any thought. TIA. |
Thanks Andy - Excuse my lazyness ... Thou shall use Search, Thou shall use Search ...
Is this link updated for V6?
Thanks! Quote:
I've been using PlaceShifter from a thumbdrive for a while and it works great. I just got a new thumbdrive that can use U3 programs. Any chance of seeing a U3 version of PlaceShifter? I can't imagine that it needs anything but their custom installer to make it work since the app is already self-contained.
SageTV v6.4.5 - Windows Vista Home Premium HP m8200n, Athlon 64 X2 6000+, 3GB RAM, 3 500 GB SATA/300 7200 RPM HDD's (2) PVR-150MCE's - (1) HVR-1800 HD ATSC/NTSC - (2) MediaMVP's - (2) STX-HD100's |
http://www.eure.ca/ It works great for creating a U3 package... -Jason
True standalone tuner functionality with the --> HAVA Channel Changer<-- |
That's so cool! Thanks! That will help with a lot of software!
Can Ver. 6 Placeshifter be run from USB
I used version 5 with great success. Is there a version 6 for USB?
You don't need a special installer for USB. Just run the regular Placeshifter V6 installer on your hard drive and then copy the Program Files\SageTV\Placeshifter folder to your USB stick.
-- Greg |
Is there a new ZIP of placeshifter for 6.1 or is this the version to use? I noticed there's no change to the files within the zip.... They are the same files used a long time ago. Thx Ariel |
I just tried it with my server running v6.1 and it works fine!
![]() (I noticed after I replied that this is an old thread.......oops)
USB Drive
Sorry to bring up an old thread, but I saw alot of responses pointing toward it.
One response said to unzip the file on the USB drive. It looks like Placeshifter is now an .exe file. So what is the best way to install Placeshifter onto a USB drive along with the license? How much room would it take? Would a 1GB USB drive work? Thanks |
This is completely optional, but if you want, you can also copy the contents of your JRE folder on your machine (Program Files/Java/jreXXX) to your new Placeshifter directory on your flash drive. Make the name of the JRE folder simply "JRE". This will let you run the placeshifter on machines that don't have java installed. Quote:
At what point should I enter the license info? I want to set this up so that both my wife or I can use it when we are traveling by ourselves with the USB drive on either of our laptops. Thanks |
You don't enter a license for Placeshifter on the client side (your USB stick, in this case). You enter the license on the Server to allow a Placeshifter client or extender to connect to it.
Gregg |
So, it sounds like you don't even have to use Placeshifter on a USB stick to do what you want to do. |
