Fusion 5 choppy recording
I cannot record HD with my Fusion 5 lite while I am recording analog tv on my dualtv or pvr150. I thought it might be the harddrive speed so I changed out the OS drive for a faster drive and it still did not help. HD records just fine as long as i am not recording anything else.
System: Nforce 3 OS drive 160gb seagate 7200.7 3 200gb recording drives, no raid all drives 64K fusion 5 lite dualtv pvr 150 SageTV server. |
Ok, so I checked the IRQ and it was the same as the Dualtv so I switched it around. Now it is the same as the pvr 150 but i disabled the pvr 150 so it should be good but it still does not work right. I read some about using the fusion 5 ts streem but all I show is WDM capture device. My hardware manager shows no ts stream capture either. Hmm. How can I fix this? For now I guess it works to turn off all the other capture devices while I watch the game but this is not ideal.
Ok, so I removed the Dualtv and put back in my 2 pvr 150s and it seems to work just fine. The problem though is that one of my 150s stops recording audio after a few days for some reason. This frustrated me so much I ended up getting the dualtv. I would like to get the dualtv working. Any ideas? anyone? Please?
Supposedly, any card with a ViXs chip currently conflicts with HD tuners. Don't know if driver releases will fix that.
P |
hmm, so how come I never saw this problem in any of the threads?
