  #301
Old 05-21-2010, 10:04 PM
rnewman rnewman is offline
In my case it was just swollen electrolytic caps.
Replaced them and all was fine.
Easy for me because I was a TV repairman back in the 60’s and been designing electronic products since then.
I believe the link someone gave me shows how to replace.
IF that is your problem and you can’t repair or get someone to repair, I can replace for you, for free, if you pay for shipping both ways. I live in Buffalo NY
Old 05-21-2010, 11:20 PM
bastafidli bastafidli is offline
It happened to me as well. Sage repaired HD100 broke again. I didn't have time to send it back again so I repaired it just myself. Got the tools/parts in Fry's/Radioshack for about $30 total and even though I didnt solder for 25 years it took me less than hour to have it all working and left me with great satisfaction.
The repair is so simple with all the instructions available here you should be able to easily do it yourself. Also the problem is so easily fixable, you should not have problem selling the HD100 e.g. on eBay if you dont want to do it.
TV: Samsung UN46D8000
Server: Intel Core i3 540, 4G RAM, Matrox G450, 70GB EXT3 encrypted software RAID1 system drive, 1TB XFS tv recording drive, 2TB EXT3 encrypted data drive mirror across 2 machines, 2TB EXT3 encrypted media drive mirror across 2 machines, CentOS 6 64 bit, Experimenting with DNLA servers
1Gb wired network
Disconnected after G day[HD 100 Media Extender, Placeshifter 7.x, SageTV 7.x, HDHomeRun]
Old 05-22-2010, 06:57 AM
I repaired mine using a 5V dc power adapter that I had lying around the house... and while the unit boots up ok... networking no longer works. I've tested the network cable, etc, and it's all fine. Has anyone else had issues with the network AFTER a fix like this??
Old 05-22-2010, 10:18 AM
reggie14 reggie14 is offline
Originally Posted by bastafidli View Post
I
Before I decide which way to go, I'd like a little more clarification on what tools I need (mainly, for desoldering), and how to desolder. The CocoonTech guide was a little vague on those two items.
Old 05-22-2010, 11:07 AM
Taddeusz Taddeusz is offline
I've never had any training on desoldering. I've never really grasped the use of desoldering braid, possibly because my iron isn't high enough wattage (i.e. get hot enough).
Basically my method was to grab the capacitor with needle-nose plyers and heat up the solder until it is liquid and pull the leads out. Make sure you note the polarity of the capacitors as you're taking them out. Then I used desoldering braid to clean things up so that the hole is exposed enough to get the new leads through. Use flux core solder to connect the new leads and a nail clipper to trim them.
Old 05-24-2010, 10:25 AM
sic0048 sic0048 is offline
To be honest, I didn't even desolder any of the units I've fixed (4 at this time). I simply used the "pin" trick where you heat up the solder enough to pull the old caps off. Then heat up the solder again and take a straight pin and stick it through the solder. Take the heat off the solder and move the pin up and down (staying in the hole) until the solder hardens. The solder will not stick to the pin and you can pull it out. This leaves you with a nice round hole to stick the new caps into. Then simply reheat the solder and it will flow around the new caps and make a good connection. You can always add a tiny bit of new solder as well.
Works just fine for me and it is much easier than trying to suck up the old solder and adding new.
Perhaps this method could eventually lead to failure, but it has been working just fine for months now. Plus I can always "fix" it again if I need to.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 05-24-2010, 10:52 AM
You can heat up the each lead and rock out.
But be VERY careful to keep heat on pin that is being pulled out.
I often add solder first to keep it molten.
You NEVER want to pull off trace on top side of pc board under cap.
Then it is almost impossible to fix. But there are ways. :-)
Old 05-24-2010, 11:08 AM
Had my First Dead HD100 last night. Chirping from the unit with a flashing red light. I bought two back in March of 2008 and one in August of 2008. The one that died was the August 2008 one (although I did replace the capacitors in on of my HD100's just to see if I could do it). Guess I know what I am doing tonight!
Old 05-24-2010, 12:19 PM
That is exactly how I do it. Sorry if I wasn't more clear. I keep the heat on the pin until it pulls out completely. It does take a rocking motion as you generally cannot get enough leverage to pull it out at once. Remember, you are trying not to burn yourself with the soldering iron either.
SageTV v9 (64bit)
OpenDCT
Old 05-24-2010, 07:43 PM
This is the exact process I use (and just used). Only took me 20 minutes to replace the caps....
Old 05-26-2010, 02:53 PM
merneric merneric is offline
This is what I use to desolder:
http://www.radioshack.com/product/in...LAID=107592455
1. Let the desolder iron heat up
2. Squeeze bulb
3. Apply to circuit for a second or two, let go of bulb, and voila!
Old 05-26-2010, 04:27 PM
Well, I tried the repair. This was my first time trying to solder/desolder anything. I found desoldering much harder than I expected, and I think I damaged the board a little bit during the repair. I found someone at work that used to do solder stuff years and years ago in the national guard, and was told that it would be easy just suck the solder with the desoldering braid. I'm not entirely sure what I was doing wrong, but I had an awfully hard time actually melting the solder with the braid and the iron, and it frequently got stuck to the board.
But my HD100 seems to work fine now. If it dies on me again I might try the external power supply method.
Old 05-27-2010, 08:29 AM
Clift Clift is offline
Reggie why don;t you do the external power adapter mod? It's solderless.
Nevermind. I hadn't checked this thread in a while and I thought your previous post on the previous page was the last one. My bad.
Server:W7 Ultimate, SageTV 7.1.9
Capture Devices: HVR-2250, 2x HD PVR 1212
Clients:
1x STX-HD100
3x STP-HD200
@cliftpompee
Old 06-02-2010, 02:32 PM
Mark57's Avatar
Mark57 Mark57 is offline
One more HD100 with two blown caps. I'm off to get parts and fix it myself thanks to the great info on this board.
Update: 30 minutes + $4.77 for 3 caps from Radio Shack and it's fixed! Sweet!!
Mark
____________________
Server: Scratch built server, 16GB RAM, Nvida GeForce 8600 GTS, 6 HD Homeruns, 32 TB Storage, Windoz 10 64 bit, Sage 64 bit 9.2.1, Sage HD-100 & 200 Extenders
Old 07-20-2010, 10:58 AM
jerryb33 jerryb33 is offline
Originally Posted by jerryb33 View Post
One of my HD100 bit the dust. Was prepared with the Caps. No issue replacing them.
All I can remember it was the second batch of units that came out.
The second one died 7/19/2010. Change caps (5 min.) and all is well.
First one died 1/27/2010
Old 07-21-2010, 09:14 AM
spence spence is offline
G-kid's fired SageTV's HD100 (my only one, everything else are 200's) up last night in the family room and there was the smell of smoke! Opened it up and the caps had popped open to let the smoke out and blacken the inside.
I'm retired from this stuff and looking things over decided to just put in a new power supply from
MPJA, Inc. 17635PS 5V, 2A MINI ASTRODYNE BOARD SUPPLY ~$6 plus shipping
Hay its overkill but it will likely out live me ;(
Spence
CAUTION: Don't look into laser beam with remaining eye...
Old 07-21-2010, 02:35 PM
jmv jmv is offline
ordered on 5/17/2008...died 7/15/2010. Daughter heard the buzzing ahead of time but didn't mention it Used the radio shack repair method and maybe 30 min all told from time of getting thing unplugged to time getting it back to the SageTV menu...
Old 07-23-2010, 08:37 PM
dadof4 dadof4 is offline
One of mine took a dump today. All the caps look fine but I replaced them anyways. Problem rectified. This forum can be, and is very helpful.
2.3 GHz AMD Phenom 9600 Quad Core, 2GB DDR2 RAM, Asus M4N78 Pro MB, XP Pro, PVR150, PVR1600, HDHR, HDPVR x 2, USB-UIRT, 160GB OS HD, 500GB SATA Recording HD, 500GB USB Media HD, HD100 x 2, HD200 x 2
Old 07-23-2010, 09:00 PM
About 2-4 years ago there was a rash of bad electrolytic capacitor from one or more suppliers in SE Asia. It affected some of the most trusted suppliers.
Not sure if they got from same manufacture.
BUT
It affected many LCD monitors and HDTV even today as well as other electronics. Put some companies out of business (was told 2nd hand).
Ray
Old 07-25-2010, 06:57 AM
The guy at Radio Shack thought I was trying to fix a Samsung TV.
Thanks for the pointers here and Cocoon Tech for the write up, I fixed 2 HD100s yest for under $20 including the soldering iron.
B
HD PVR power supply Fingergottes Hardware Support 1 09-22-2008 01:13 PM
HD Homerun Power Supply Eckwell Hardware Support 12 09-10-2008 08:28 AM
power supply opinions, please hemicuda The SageTV Community 6 06-12-2008 08:29 AM
Silent/80 Plus power supply? morikaweb Hardware Support 12 02-22-2008 11:54 PM
Weak Power Supply ? 65 W Droid Hardware Support 4 03-04-2004 07:55 AM
