Old 09-07-2010, 07:32 AM
rxnelson rxnelson is offline
DTS-MA to DTS
I am new to sage (thinking of converting from BTV) and I can't get BD rips with DTS-MA to send the "core" to my receiver which is hooked up via optical and can't do DTS-MA but can do DTS. I am using an iso rip and the same file plays fine in PowerDVD9 which came with my burner. In fact on the info screen in PowerDVD I can see it is detected as DTS-MA but the output is DTS compressed. Somehow the software "knows". I am guessing because I picked SPDIF as the output and you can't output DTS-MA on SPDIF AFAIK. So anyway is there a similar checkbox or something in sage? I played with the codecs, ac3filter, and other audio settings but can't seem to get it to work. The receiver either does nothing or skips and goes in and out. I am not really interested with re-encoding my files to AC3 or DTS. At this point if sage can't do it I would rather it just launch PowerDVD and play there if that is possible. I posted this in the sage7 beta forums because like I said I am only using 7 and have no experience with v6 and what it can and can't do.
Thanks.
Old 09-07-2010, 09:22 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
We were just discussing this internally on Friday and will be adding it soon so you can enable/disable hd audio and use the core streams instead.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 09-07-2010, 10:41 AM
Great....what will I drive myself crazy with in the meantime?
Seriously though I am in trial mode. Granting an extensions? This and video failure when playing from the actual BD drive are my two main hangups right now. I have yet to fully analyze this problem. It's seems strange. I can play the actual disk with the arcsoft or PowerDVD and the rip plays in sage. I looked on the internet and I don't think the disk was VC-1. I will probably just post another thread.
Thanks for the info.
Old 09-07-2010, 12:24 PM
TwistedMelon TwistedMelon is offline
AFAIK, your trial will be extended when you install the new beta version. So that shouldn't be an issue.
Bruno
Twisted Melon Inc.
While you're clicking, check out my Mini Theater custom build.
Old 09-07-2010, 03:37 PM
Rico66 Rico66 is offline
Not sure, if this is the same issue as described in this thread (http://forums.sagetv.com/forums/showthread.php?p=440220), but you could temporarely try the listed registry modification (which requires e.g. a splitter like Haali)
Old 09-07-2010, 07:26 PM
I am not sure it is the same issue. That post was a month old and I think I have a newer build with the fix. I think this issue for me is that it is passing hd audio(dts-ma) to the receiver that can only handle DTS. Sounds like the fix of enabling/disabling hd/core will do the trick.
Thanks.
Old 09-07-2010, 10:44 PM
Jeff, while you guys are looking into tweaking the stream selection, any chance you could toy around with setting up some sort of client capabilities options? It seems it would make sense to let you choose what formats your particular client supports, so it can automatically select the proper types. This, i would think, could ultimately lead to selective transcoding for those 'more limited' clients.
Old 10-11-2010, 10:01 PM
I installed version 0.20. I still can't get DTS to play when DTS-MA is the only track on the rip. Maybe I misinterpreted what is supposed to happen. I assumed if there was a DTS-MA track you could leave it and since that new option is set to disabled DTS would play. I had some issues with DTS playback on 0.17 and 0.18. The newest version seems to have cleared that up so I am back to where I was with 0.16.
Old 10-11-2010, 11:07 PM
What is the source of these files? I ask, because you CAN have a DTS-MA track, without a DTS core (I think some HD-DVD's had this).
Old 10-11-2010, 11:12 PM
I ripped my IROBOT BD. I believe the track to be there because PowerDVD plays audio on the same iso.
Old 10-11-2010, 11:19 PM
Can you play any other DTS videos from in sage? you may have a codec issue.
Old 10-12-2010, 04:16 AM
If I use eac3to or whatever it is to convert DTS-HD/MA to DTS it will play....wouldn't on version 0.17 or 0.18 (I submitted a bug and a file) but now it will.
Old 10-12-2010, 07:01 AM
Polypro Polypro is offline
Even with "HD Audio" disabled, it is selected during playback as default...and you get no sound. If you bring up the currently playing file options, you can go to "Audio Language" and select "#2 AC3 5.1" (or DTS) and you will get audio...but I always get a foreign language. WMP does the same thing, so it isn't just Sage.
P
Old 10-12-2010, 07:45 AM
rparker rparker is offline
you have to use hdmi for higher level audio.. optical can not do the higher audio. too much data and it needs to 10gb bandwidth
Old 10-12-2010, 01:21 PM
No offense meant but I already knew that. My question I guess is now whether Sage intended me to be able to pick different audio streams from the menu (not what I thought they were doing) or can it "strip" the DTS-MA/HD audio down to the core and send that to my receiver the way PowerDVD and Arcsoft do.
Old 10-12-2010, 01:23 PM
P
I am pretty sure it doesn't have any other tracks listed. Like I said PowerDVD just does it. I can see the input as DTS-HD and the output as compressed 5.1 or something like that when I pull up the info screen. I think the HD300 does it as well if you have your audio set up correctly on the device.
Old 10-12-2010, 11:24 PM
FYI - Your trial is not extended by installing a newer beta version. Just tried on my Windows 7 box for some testing I was looking to do. Might just be time to fire up a VM!
-Striker-
Old 10-13-2010, 12:12 PM
Suntan Suntan is offline
Along these lines, it would be pretty sweet if you could configure individual extenders to "prefer HD audio over core when available" or "use only core" in a setting.
As it stands, I have to add an AC3 track into DTSHDMA BRs so it will play on the extender in the bedroom. But then I have to go into the menus and select the DTSHDMA track manually if I watch it in the basement. Having the two extenders always preference one or the other, regardless of which audio track is 1st or 2nd, would eliminate that...
...Or a person could have the option of sage automatically transcoding the DTSHDMA to AC3 on the fly, thereby eliminating the need to add the secondary AC3 track...
-Suntan
Old 10-13-2010, 03:28 PM
Just replace it with an HD300.. it'll decode the DTS for you...
Also, the new HDAudio or CoreAudio setting is a per-client setting, so you CAN have some output the DTS-MA, and others output the DTS Core... but there is no way to have it decode the DTS and output AC3.. well, not on an extender...
Old 10-13-2010, 04:11 PM
I think FFDshow will do what you are wanting.
DTS-HD, DTS-HD MA, Dolby Digital Plus, TrueHD manufuji SageTV HD Theater - Media Player 3 07-26-2010 08:50 PM
DTS issues valnar SageTV Beta Test Software 2 11-14-2009 11:42 PM
Thanks for DTS support panteragstk SageTV Beta Test Software 3 01-06-2009 08:34 PM
DTS audio ukbballrulez33 SageTV Media Extender 16 11-14-2008 03:23 PM
DTS to AC3 ukbballrulez33 General Discussion 6 04-08-2008 11:08 PM
