SageTV Placeshifter Discussion related to the SageTV Placeshifter application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the SageTV Placeshifter software application should be posted here. |
Client Vs. Shifter
Is there anyway to get placeshifter to run dvds off hard drive? I know you need client to do this, but placeshifter just seems more stable?
Thanks Mo |
Maybe you could if you first convert it to something that is no longer in DVD format, so it can then be played as a straight video file. Before the MVP extender could play DVDs, people would import the VOB files and play those in a playlist. I'm not sure if you could do the same in Placeshifter. - Andy
Wired MVP Losing Connection | MeInMaui | SageTV Media Extender | 12 | 09-20-2006 05:53 PM |
Issues with MVP client, Neilm's Customizable Menus, and java version | zubblwump | SageTV Customizations | 8 | 09-07-2006 10:12 AM |
Client cannot connect?! | Jesse | SageTV Software | 9 | 08-23-2006 04:23 PM |
Using Sage Client to view media stored locally | Steerpike | SageTV Software | 4 | 04-11-2006 05:45 PM |
SageTV Client Issues | RickD | SageTV Software | 12 | 01-28-2006 08:18 PM |
