USB-UIRT double entry
When using the hauppauge 45 remote with the USB-UIRT I have to double all commands (example hit Play Play to Play, Press Up/UP to scroll up, volume twice up or down) and so on.
Anyone have any suggestions? Thanks ![]() ![]() ![]() ![]()
Windows 7 Ultimate / SageTV server/client 7 / ZOTAC GeForce 9300 4 gig memory / Hauppauge 2250 / USB-UIRT / DirecTV D12-100 / 2-500 gig SATA drives / wireless keyboard. Last edited by mclement60; 02-16-2011 at 08:15 PM. Reason: Title |
The Hauppauge remote uses a toggle type of IR code, so each button emits two different IR codes when pressed repeatedly -- you have to learn each button twice with the USB-UIRT w/o pressing any other remote button in between.
| Tags |
| commands, double, usb-uirt |
| IR USB Blaster Other Than USB-UIRT? Driving Me Nuts-Can't Remember | Savage1701 | Hardware Support | 7 | 01-21-2011 06:58 AM |
| USB-UIRT | pknowles | Hardware Support | 3 | 09-01-2009 07:42 PM |
| double transmit UIRT | jepalmer1391 | Hardware Support | 4 | 12-13-2008 12:44 PM |
| USB UIRT is sending double digit of the number | mistergq | Hardware Support | 4 | 08-29-2008 08:04 PM |
| USB-UIRT Remote Commands Executed Double | RAlfieri | SageTV Beta Test Software | 11 | 12-18-2006 04:59 PM |
