How to get forced_video_storage_path_prefix working?
I'm having trouble getting the forced_video_storage_path_prefix tag working.
I have 2 HDHR's and 1 HDPVR and want to put 3 tuners on one drive and 2 tuners on another drive. I have added a new hard drive and set it up as a recording directory. I then stopped Sage (Service in WHS) Edited the Sage.Properties file for each tuner and changed it between mmc/encoders/-1071484547/forced_video_storage_path_prefix=\\\\Sage\\SageTV and another tuner of forced_video_storage_path_prefix=\\\\Sage\\SageTV2 My two recording UNC paths are \\SAGE\SageTV and \\Sage\SageTV2 When I try to record multiple show's, it's only recording to the SageTV2 UNC path. Is the tag case sensitive? Any other reasons why this might not be working? Thanks Dave |
I'm guessing that \\Sage\SageTV2 has the most available space, so that's why the recordings are all going to that location.
The property defines a prefix, meaning that prefix is used to match whatever recording dirs start with the prefix you define. Since \\Sage\SageTV2 starts with \\Sage\SageTV, you are telling some tuners to use \\Sage\SageTV & \\Sage\SageTV2 and some to only use \\Sage\SageTV2. i.e.: you'll need to come up with distinct prefixes if you don't want the tuners to use the same recording dirs. - Andy
Thanks!!!
I change to \\\\Sage\\recorded and it's now working perfect!!!! Dave |
Can you point me to the docs on this? I can't find it in the manual or via forum search. Thanks Scat
Server: Intel i7-930 CPU @ 2.8GHz , 300GB HD, 24GB DDR3, Win 10 64-bit, (2) 2TB HD for recording Capture Devices: 2xHD Homerun Prime 3 (CableCard) = 6 Tuners (Spectrum, TV package: Select), 1xHauppauge WinTv 885 (4 tuners OTA), 1xHauppauge WinTv-7164 (2 tuners OTA), Schedules Direct EPG NAS: Synology DS1618+ 26.2TB Synology Hybrid RAID (SHR) Sage Add-ons: Comskip Plug-in Eventghost 0.5.0-RC4, Java Version: 1.8.0_172 (32-bit), Harmony 880, USB-UIRT |
You can try searching the forum for something like forced_video_storage* instead of the full property name. - Andy
Does this feature require UNC paths or can I use actual paths like:
D:\Recordings and E:\Recordings IE: mmc/encoders/-112107779/forced_video_storage_path_prefix=D:\Recordings
If this doesn't work right, Then: "I'm going to blow up the Earth!" |
Drive letters should work, but remember to double up the backslashes.
-- Greg |
Could you give me an example?
It has to be a prefix for a recording directory, so just use the values from the seeker/video_storage property as the basis for the prefix.
Similar Threads | ||||
forced_video_storage_path_prefix | davey_fl | SageTV Software | 1 | 02-16-2009 01:12 PM |
Does anyone have HD working well??? | COLO_PVR_GUY | Hardware Support | 19 | 06-26-2008 02:33 PM |
forced_video_storage_path_prefix - Is it possible to set local and UNC path? | zzmystique | SageTV Software | 3 | 06-07-2008 09:42 AM |
Does forced_video_storage_path_prefix failover if full? | GollyJer | SageTV Software | 3 | 11-29-2007 07:04 PM |
forced_video_storage_path_prefix | Wheemer | SageTV Software | 1 | 01-18-2007 06:22 PM |
