Old 06-22-2010, 09:48 AM
Savage1701 Savage1701 is offline
Can HD-PVR Brightness, Saturation, Contrast, etc. Be Controlled From Properties File?
I am noticing some of my channels seeming very washed out with HD-PVR recordings, especially the 480i stuff I have locked at 1080i.
Can I edit the brightness and contrast in the properties file? It's not an option in the Video Sources area of the Sage interface.
Anyone have any starter suggestions?
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR.
Old 06-23-2010, 11:39 AM
darcilicious's Avatar
For what it's worth, I think the default contrast/brightness settings for the HD-PVR in V7 are noticeably less washed out.
Old 08-03-2010, 01:23 AM
HKme HKme is offline
Similar issues here. I have two sources, HD-PVR and DVB-T USB stick. The DVB is fine, but the HD-PVR is too dark on most channels. Using 7.0.12.
I had been looking for a way to adjust brightness/contrast etc. on a per video source basis and came across brightness/contrast/hue/saturation/sharpness settings for each encoder in the sage.properties file.
Before I start experimenting, does anyone know what ranges these settings use and if they're supported for the HD-PVR? Also, is there somewhere in the main program interface that I have missed where these can be set?
Thanks.
Old 08-03-2010, 01:42 AM
GKusnick's Avatar
GKusnick GKusnick is offline
I don't have an HD-PVR, but look for a Color Calibration button on the Source Details screen. That's where it is for some older SD analog encoders anyway.
-- Greg
Old 08-03-2010, 07:41 AM
They weren't supported in v6 of Sage even though the controls were visible in the Source Details area; I haven't looked in v7 because it's the only tuner I have and looks great now...
Old 07-28-2011, 03:42 PM
wbarber69's Avatar
wbarber69 wbarber69 is offline
Send a message via ICQ to wbarber69 Send a message via AIM to wbarber69 Send a message via MSN to wbarber69 Send a message via Yahoo to wbarber69
ok I installed the beta drivers from hauppauge and afterwards the brightness amd contrast were all washed out so I came here looking for a soluion. I wanted to post this before anyone else had this problem and ended up here with no answer. I found the solution. Just stop using the HDPVR, open up Total Media Extreme. Go into record a video. Select Device Settings. Hit Default. You should see an immediate difference in the preview window. Then just close and continue using HDPVR as usual.
So far I'm not having any problems with the new drivers. I am not using the internal blaster (I'm using FWChannelProxy). And I use the USBUIRT to handle my Remote Control needs, so I cant relate to the problems of the HDPVR freezing up from too many ir commands.
Old 07-28-2011, 06:45 PM
You might try rebooting your server. I heard those settings don't stick.
Old 08-01-2011, 01:01 PM
wbarber69's Avatar
My bad I meant to also mention that you need to take these values that the program gives you for hue, contrast, etc. And plug them into the sage.properties file where it shows your hdpvr settings
Old 08-01-2011, 02:09 PM
doncote0's Avatar
doncote0 doncote0 is offline
Red face Example?
What was your information that was entered?
Old 08-07-2011, 05:32 PM
wbarber69's Avatar
I went with
128
64
128
64
128
But your favorite settings may be different
Also to note in tme the hue setting for 0 doesn't calculate to sagetv settings for 0 so 0=128 as hue settings can only be changed by a value of +/- 30
Old 08-08-2011, 11:04 AM
doncote0's Avatar
Talking Cool!
Old 09-01-2011, 02:54 PM
BitBass BitBass is offline
I'm not seeing where in sage.properties to plug in the settings. Searched it for pvr and haup and nothing that looks like a match.
Win7 VM -4gb ram
Ubuntu 14.04 VM -4gb ram (attempting with OS v9)
3 extenders through the house
Plex integration
HDHR
Old 09-01-2011, 03:02 PM
Nevermind, I figured it out!
Win7 VM -4gb ram
Plex integration
HDHR
Old 09-03-2011, 02:54 PM
peptide peptide is offline
Could you post the solution? I am experiencing the same problem; I just updated my HD-PVR driving and now TV/recordings are washed out. The TME settings work withing TME and are persistant, but I can't find how to control these values in SageTV.
Help!
Mike
Old 09-11-2011, 10:27 AM
bling_bling_vr6's Avatar
bling_bling_vr6 bling_bling_vr6 is offline
Send a message via AIM to bling_bling_vr6 Send a message via Yahoo to bling_bling_vr6
I have a HD-PVR, am running v7.1.9 (or whatever the latest is now) and was having issues with way too much gamma and washed out colors. What some are saying happened to me too...where I was able to go into Total Media Extreme and set the default settings and then video appeared fine in sageTV for a while, but whenever I restarted SageTV the color values would get screwed up again. Here's what I found:
1. SageTV has messed up default brightness, contrast, hue, saturation and sharpness values for the HD PVR Capture device.
2. You must fix the values in 2 places in sage.properties for them to stick.
3. You must change your sage.properties file when sageTV is shut down.
To find my encoder (the HD-PVR) I looked for its unique encoder number in the sage.properties file. its the xxxxxxxxx number on a line like this:
mmc/encoders/-xxxxxxxxxx/video_capture_device_name=Hauppauge HD PVR...
All settings with that xxxxxxxxx number belong to that capture device, including 3 instances each of brightness, contrast, hue, saturation and sharpness. You can leave the ones set to -1 alone, but the other two that have values set I changed to:
brightness: 128
contrast: 64
hue: 125
saturation: 64
sharpness: 128
Save the sage.properties file, startup sageTV, tune to a channel that uses your HD PVR recording device and ensure that everything looks good.
Boom, done.
SELECT * FROM users WHERE clue > 0
0 rows returned
Old 10-20-2011, 11:26 PM
Diego Garcia Diego Garcia is offline
A quick follow-up, if I may...
I've run into the same washed out problem with the newest Hauppauge drivers. But I'm also running into a problem where the digital capture from the HDPVR gets all sorts of artifacts in it. It's like certain elements of certain scenes get badly pixelated (or look like what happens to a digital TV display when the signal is weak).
Has anyone else run into this? If so, how did you fix it?
Old 10-21-2011, 04:38 AM
The fix is in this thread. Have you read the thread?
Old 10-21-2011, 08:16 AM
Yes. But I saw no mention of the pixelation problem, which also appeared with the new drivers.
Old 10-21-2011, 01:07 PM
Hmmm-didn't see that on mine. Did you actualy change the settings and viewed it?
Old 10-21-2011, 01:27 PM
Haven't had the time to do it yet. I just used TME to adjust the HDPVR parameters, which improved the picture quality in Sage a LOT. But of course those changes won't survive the next system restart.
I was just curious if anyone else was having pixelation problems with the latest HDPVR drivers. Frankly, since the previous drivers were working fine for me I may just drop back to them.
Can you change brightness/contrast etc. through the HD100 Chriscic SageTV Media Extender 1 08-04-2008 02:19 PM
Increase brightness level on HD-PVR? popechild Hardware Support 0 08-04-2008 10:23 AM
VideoRedo using contrast and brightness? steingra General Discussion 0 11-25-2005 10:28 PM
Roslyn users: Contrast/Brightness issues sleight42 Hardware Support 25 07-20-2004 09:38 AM
How do I adjust brightness/contrast... jbuszkie SageTV Software 8 10-17-2003 09:32 AM
