Old 07-17-2010, 12:20 PM
SprDtyF350 SprDtyF350 is offline
Program guide and MVP
I still use a couple of MVP's. The latest 7.0.12 update has made the program guide near unusable with them. Is there a way to switch back to the old version? I am using the standard STV's. Have tried both V3, and V7. You cannot tell where you are in the guide anymore. I don't want to stop using them because they do a great job where I have them.
Old 07-17-2010, 09:47 PM
SuiDog's Avatar
SuiDog SuiDog is offline
I was having the same problem. Here's what I did.
1) Setup -> Help -> View TV Categories .. Delete ALL categories (5 or 6).
2) Setup -> Plugins -> All available -> Themes -> install the MBdiamond theme
3) Here was thing that really helped.. on the MVP the yellow button at the bottom opens the options menu (I didn't know this).. then I changed the font and the amount of columns to my liking. I can actually use it now on my 18" from about 7' away.
Hope that helps.
BTW, I changed the columns and font for all of the menus.
Server: i3 530 dual 2.93Ghz, 6GB mem, 2x 3TB 7200 rpm sata drives, Windows 7 ultimate 64-bit,Sagetv7.1.8 Beta
Clients: 3x Hauppauge MediaMVP, 1x HD200, 1X HD300.
TV provider: Comcast Digital, Up to 8 recordings at one time. Ceton 4 tuner cable card. 2x Dual Tuner HDHomeRun's (SageDCT 1.4 Ceton 1.0.6.1
Old 07-18-2010, 09:12 AM
Well that works a lot better. Not as good as it used to be but at least the guide is pretty much usable again.
The good old MVP lives to watch another show!!
Old 07-19-2010, 06:15 PM
FMAX's Avatar
FMAX FMAX is offline
Thanks.....
Just wanted to state that I was disappointed in the MVP performance with version 7.
Your Post was a huge help.....MVP lives again.....
MVP Sluggish problems no more....
Old 07-20-2010, 10:23 AM
I submitted a Bug report and this was the answer. It works perfectly..
"Thanks, this'll be fixed for the next build. For now you can set:
ui/allow_transparency_disabling_for_non_layered_clients=false
in your Sage.properties file to resolve the issue."
Program Guide is gone! freewheeling SageTV Software 3 07-15-2010 10:56 PM
STV Import: Alternative Program Guide & Mini Guide for Default STV wado1971 SageTV Customizations 24 09-13-2009 01:32 PM
Program Guide doesn't look right in v6.2.5 bcjenkins SageTV Beta Test Software 6 08-03-2007 07:02 AM
How to disable the popup window in the program guide? How to keep the program guide? metropole SageTV Software 8 05-18-2006 06:25 PM
