Old 08-05-2010, 03:11 AM
Spectrum Spectrum is offline
Accessing USB-UIRT from service and client
So, Jon was kind enough to provide a beta driver that allows this to happen. I have had it installed for about 12 hours and it has been working fine.
He said "it has some pretty extensive changes (a lot that involve security permissions and restrictions that came along since Vista) so I may not put it in a standard release for a while but make it available for those that ask." so I'm attaching the updated dll here.
Installation instructions:
You will need to copy this overtop the version you have installed on your system.
Note that you will likely find the driver in two places on your system:
C:\windows\system32\uuirtdrv.dll
And
C:\Windows\SysWOW64\uuirtdrv.dll
Note also that you will need to temporarily STOP the SageTV service before you
will be able to replace these files, or they will be 'in use' by the system.
Remember, this is a beta driver so all caveats that go with beta software apply and if you have any problems with it give us all a heads up and I'm sure Jon would be interested in the problem and how to reproduce it
Old 08-05-2010, 12:39 PM
DeanONH's Avatar
DeanONH DeanONH is offline
Where can I find a API definition for the new driver?
Thx,
Dean
ASUS 2.5GHz QuadCore, Win 7 Pro x64, 8GB RAM, 1TB HD, 2TB RAID NAS, 58" 1080P Plasma
2 HD PVRs, 2 Motorola STBs, 1 USB-UIRT; LM Remote KeyMap for "On Demand"
2 HD200s, 2 32" 720P LCDs, 2 URC-WR7 Remote Controls
2 Laptop Clients, 2 PlaceShifters
Old 08-05-2010, 07:26 PM
Thx,
Dean
Not sure about API definitions, I posted all the info Jon sent me.
Old 02-19-2013, 10:52 AM
pricequest pricequest is offline
The beta driver above has been working for well over a year; just wanted to note that if you plug in the USB-UIRT into a different USB port, the OLD driver might automatically overwrite the beta driver (win7 x64 copies the default driver in C:\Windows\System32\DriverStore\FileRepository\ftdibus.inf_amd64_xxx). Just copy the driver again, and make sure that if you're on win64 you copy the beta driver to C:\Windows\SysWOW64 as well as the 32-bit path. Also, using a dedicated USB PCI card for the USB-UIRT eliminated all issues where it would intermittently disconnect (I have 2 HD-PVRs which may have been related to the disconnections).
Anyone successfully using USB-UIRT w/ Vista AND service mode? popechild Hardware Support 8 02-27-2011 02:44 PM
Accessing files on usb device connected to HD200 from XP clarenceb5 SageTV HD Theater - Media Player 1 08-19-2009 03:39 PM
Trouble accessing USB Drive from PC montaspm SageTV HD Theater - Media Player 4 07-07-2009 06:26 AM
Usb Uirt doesn´t work in Sagetv Service mode in V4 Nadim Hardware Support 3 12-08-2005 12:32 AM
Usb-uirt, Girder, Sage Recorder And Client Crowdx42 Hardware Support 0 05-17-2004 03:04 PM
