New MCE Remote Software
Hello All,
I just updated my remote software for the Streamzap / Firefly / Firefly Mini remote to also include support for the Media Center Remote (it works only with the 2005 MCE Remote). So among other things you will be able to : * create more than one remote profile for matching applications (window title / window class name / executable name) * assign each button an action to do (sending keystrokes, messages, app command and so on) * nice transparent OSD for volume * menu system with OSD for having keys with more than one function (donators only) * OSD for multipress keys (tap one it does one thing, tap twice it does another thing). * Mouse Mode You can download and read about it on my web site. License : Donationware Note : you will need the default MCE Remote driver that comes with XP SP2 or Media Center (not those modified drivers you can found on the GreenButton web site). You can also have some "double" key press behavior with some keys. So let me know if this doesn't work for you and what exactly are the buttons that doesn't work properly with which applications. I'll add IR blaster support later Best Regards, Stéphane. |
I'll give it whirl. There are a few mce keys I'd like to remap. Cheers Mark
Luckily Computers Repair Themselves |
Hello Mark,
Other than that, as this software is already working well with all the other remotes (I use it with the Streamzap and SageTV) so there should be no surprises with its features ![]() Regards, Stéphane |
Hi,
I just tried to load it, and got the message that it needs .net 1.xxx (I forget the exact version). I have .net 2.0 installed (as of this morning), do I need to install previous versions as well. (Apologies if this is a dumb question - my client is not on my home network due to bloody massive thick walls, so I have to move all files around via a usb key at the moment). Cheers Mark
You were up late last night!
Do you have a 'default' profile for sage? EDIT: I just tried the profile download option. I've entered my username and password (obtained through the 'Forgotten Password' link in the pop-up) but it does not recognise me. I donated for your XMLTVImport utility.
Setup: - Server - Intel 3.4G D + XP, 2Gig ram, 3TB of raid. All running in service mode with 2 Hauppauge HVR4000 Running v7 with LMGestion's XMLTV and DG2XML. I also have the web server running. Client - x2 plus PlaceShifter on various machines including eeepc Ubuntu 8.04. I am streaming Live TV to my PocketPC. Stable but can use DVB-S on second HVR400. Last edited by motobarsteward; 02-26-2007 at 03:03 AM. |
Also just a quick note about the "PC Power" buttons of the MCE Remote. By default this button will put you computer into standby. If you do not want that this happens, you have to go into the control pannel / Performance and Maintenance / Power Options, click on the "Advanced Tab" and choose "Do Nothing" for "When I press the sleep button on my computer".
Then you can choose in LM Remote KeyMap whatever you want for the "PC Power" button (even putting the computer into standby or hibernation). Regards, Stéphane. |
. More seriously, it may work with the previous remote but certainly not with the software I released because I'm pretty sure the hardware Ids will not be the same (so it will work for Arrow keys / Number buttons / some of the play / pause controls but not the other).Also the blaster will definitely not work (currently the function is not enabled in LM Remote KeyMap). So I would suggest to try the software first and if it does not work, send me an e-mail to lmgestion@hotmail.com with a picture of your remote (so I can create a new template) and I'll send you a HID test software where you'll be able to create for me a report for each buttons of your remote. Regards, Stéphane. |
Funnily enough, the MCE remote I ordered arrived today :-)
Seems to work OK with Sage but I have a couple of queries I'm not getting any on screen volume display when remote keymap is running (I checked and I get it when it is not) I tried playing with the transparency setting with no luck The MCE power button (once I stopped it shutting down my PC!) doesn't do anything, I wanted to map to ctrl+z to put Sage to sleep (Like the Hauppauge 45 button remote green button does) but I can't seem to find how to map a key sequence [edit] I just RTFM and found 'keystroke' as opposed to 'presskey' and mapped it to ^z Tim
Tecra M5, 2 x HD200, 2 x HD300 2 x PCTV 290e Win 7, Sage 7.1.9, Phoenix 2 STV Stephane's XMLTV Importer, Digiguide, Last edited by brewston; 02-26-2007 at 04:00 PM. |
Hello Tim,
Another way to verify that all is working properly, is to use mute / volume+ / volume- when no applications are launched : does the buttons are indeed changing your master volume ? Quote:
Yes, the power button works for Sage's sleep function perfectly :-) Tim
Tecra M5, 2 x HD200, 2 x HD300 2 x PCTV 290e Win 7, Sage 7.1.9, Phoenix 2 STV Stephane's XMLTV Importer, Digiguide, |
This is cool but one question.
Can I stop the green button from launching MCE. Presently I use the MCE custom drivers that allow you to redefine all the buttons and use it with HiP. |
* Buttons that are like real keyboard keys : Stop / SkipBackward / SkipForward / Back / Up / Down / Left / Right / Ok / VolumeUp / VolumeDown / ChannelUp / ChannelDown / Mute / Number buttons / Star / Sharp / Clear * Buttons that are HID messages (all other buttons), so the Green button is one of them. For the "keyboard" type button, LM Remote KeyMap will stop the event propagate so no other applications will see them. For the HID buttons, I cannot stop other applications to listen to them. So if there is a MCE service that listen to the remote : it will trigger the "Green Button" press and launch MCE. So the only solution with my software is to stop the MCE service. On my XP Pro PC : the Green button does nothing unless I assign it an action in my software. The same is true for PVR applications : if there is a MCE Remote native support in the software, you'll have this time to "nullify" those buttons in LM Remote KeyMap (that is assign them a blank "keystroke" action). Regards, Stéphane. |
I tried adjusting the volume before starting Sage and still don't see anything. My sound device is the Nvidia onboard sound on a Shuttle SN95G5. I use AC3filter within Sage, will that effect anything ? (it only passes through AC3 & DTS, the other sound is always controlable via Sage) Tim
I tried unchecking and checking that box but it made no difference. I pulled up the Windows sound control from control panel and the volume slider moves when i change the volume on the remote Thanks for the assistance Tim
| MCE remote driver for XP Home? | blade | Hardware Support | 25 | 02-17-2012 07:55 PM |
| MCE remote transmitting keypresses twice | arnabbiswas | Hardware Support | 1 | 02-22-2007 10:55 AM |
| mce remote conflict with xbox 360 | tsitalon1 | SageTV Beta Test Software | 1 | 12-01-2006 06:21 PM |
| Do i have my remote control options understood | orangezero | Hardware Support | 6 | 05-05-2006 10:32 PM |
| Can MCE Remote configuration be customized? | TwistedMelon | Hardware Support | 6 | 04-25-2006 08:45 PM |
