#201
Hello,
* you use the "ChangeVolume" action * whenever master volume change, if you checked the "show volume osd whenever volume change" So you can : * uncheck the "show volume osd...." * not use the "ChangeVolume" action OR choose to display the OSD offscreen (top/right or bottom right) by using the position sliders when you click on the "Options" button for the Volume Osd Skin. Regards, Stéphane. |
#202
This way you'll have the default behavior of a multimedia keyboard. Quote:
#204
Unfortunately MediaVolumeUp/Down do not display any OSD at all, so also not good.
I understand that you want ChangeVolume to use a consistent system-wide OSD, but what's the harm in allowing that override OSD to be disabled? If the Microsoft OSD was used and only appeared at the same times it appears without the software running at all - in other words, no override at all - I'd be happy. I understand this might not be possible as I don't know the details of how a program like this works. I don't mean to nitpick, just really trying to see if I can get this program to suit my needs. ![]() |
#205
In your case it seems that the Microsof OSD only react to the VolumeUp / VolumeDown keyboard keys pressed event (whereas it should react to the volume change event...). |
#206
Quick question, would it be possible to store the config and preferences data in the user's personal app data directory if they chose "Just Me" for install, instead of in the "all users" app data directory? This would be the appropriate spot and is handy for consistency purposes. Thanks again. |
#207
Moreover, the "Just Me" / "Everyone" option in setup should not be used to make change to the very location of the configuration storage, but only to add a shortcut to the application in the right place (that is in the Start Menu for all users, or for the current user installing the application) Regards, Stéphane. |
#208
Thanks, Stephane. The software is working really well for my needs. I seem to be having a problem with AppActivate, however. Since the arrow buttons, numbers, etc. are just keyboard hooks, I do not want them to control Sage without Sage having focus like the other buttons. But, I want those other buttons to give Sage focus when pressed so that the arrow keys and all that will then work for Sage. I do this by doing a FindWindow, then a 1000 ms Pause, then an AppActivate and finally a SendMesage. The message gets sent and the command in Sage is executed, but then about half the time Sage has focus (arrow buttons work in Sage), and the other half it doesn't (arrow buttons are controlling whatever else I was in, like the desktop). I can't figure out why it's inconsistent. I've used both SageApp,SageWin for FindWindow (what I used to use for the Hauppauge remote) as well as SunAwtFrame,SageTV (this is what your software picks up for SageTV when I press the "record" button). The behavior appears the same for both.
Again, thanks. |
#209
#210
First off, I want to say thanks for this application. For the most part it has been working great. The only issue I have, keeping me from moving this into the living room to replace my DirectTV DVR is that it still takes too long to change the channels. I've played with various settings, but it is still taking longer than I would like. Is there a way to configure it such that it sends the key I press as soon as I press it, versus SageTV waiting for all three digits to be entered then sending the digits to my DirecTV receiver?
Thanks and regards, Mike |
#211
Hi Mike,
#212
Stephane,
Thanks for the quick response. I have one other question then. After enter the three digits for a particular channel I press the enter button, which I beleive is mapped to the Enter/Select button for my DirecTV receiver, it seems like that is not being passed to the IR Blaster. I can see the three numbers enter on to the screen (from the receiver, not SageTV), but there is a pause before it actually changes channels, the same type of pause I get when I don't click enter after keying in the three digits (DirecTV has some channels that are 4 digits, so the receiver waits for you to enter a fourth digit prior to changing the channel if you don't click enter). Thanks, Mike |
#213
In the IR Device editor, type the name of your "Select" button (as you see it in the tree) in the "Send these commands after channel change" field. Note: you do not need to restart LM RKM or SageTV for this to take effect. Regards, Stéphane. |
#214
That makes sense now, I thought the "Send these commands after channel change" would be sent with each digit that was pressed, but since SageTV essentially batches the digits into one channel change event I can see how this works. I'll give it a try when I get home.
Thanks again, Mike |
#215
Stephane,
I have been using LM Remote Keymap for a few days now with an MCE remote and I'm noticing a strange phenomenon. When LM RKM is running, a channel up or channel down command is being issued twice per button press. It happens too fast to make a difference when actually changing channels; however, when using it to page through the program guide, the guide jumps 2 pages for every button press! I do not have LM RKM set to intercept or modify the channel button, only the PC power button and the # key. Both of which are mapped to keystrokes. Just thought I would let you know about it and check to see if you had any ideas on why it might be occurring. If you need any more info, let me know and I'll be happy to provide it. |
#216
Hello,
So when you have double key press, it means that the application you are using is responding to the button press without needing any third party software. You have then two options: * either configure the application to not respond to the MCE button press (in SageTV it means that you have to selet "No Remote") * or assign a "None" action to the affected button in LM RKM for the application profile. Regards, Stéphane. |
#217
I did not realize that LM RKM was intercepting and sending button presses when there is no action is assigned. I'll assign a none action to the channel button when I get home. Thanks for the response and I'm glad it was nothing more than a case of me being dense. Seems to be happening more and more these days ![]() |
#218
Would it be possible to add support for the xbox 360 remote? This remote sends commands that can be received by the normal MCE remote receiver (most keys are the same as the normal MCE remote), but has extra keys that are handy. My harmony lets me send all of the ir codes, so these gives me the ability to map more sage commands to the remote since I am out of keys as it works right now.
The main reason I want to do this is to try and enable discrete IR commands for on/off, as the toggle is causing some WAF issues right now. My goal is to tell Vista to ignore the "sleep" button for shutdown (which should mean if the power toggle ir code is set, it will do nothing), so if the system is up and gets a power toggle ir code, nothing happens. But it should still wake up the system, turning it effectively into a discrete "on" code. Then I'd take another unused ir code, use your app to map it to suspend, and effectively this turns this new ir code into a discrete "off" code. I haven't found a more elegant way of solving the discrete on/off code problem, but if anyone has a better idea that would be great.
Server: Sage 6.5.9 - X2 3800+, DFI NF4 MB, 1 GB, 300 GB HD (system disk), NV 7600GS, - Windows XP SP2 Client 1: Sage 6.5.9 - E7200, Abit IP35 Pro, ATI 4850 with HDMI connect to Denon 3808CI and Sony A3000 SXRD TV Client 2: HD200 connected to Denon 3808CI and A3000 SXRD TV Client 3: Media MVP to 15" Toshiba LCD Client 4: HD100 connected to Samsung 23" 720P LCD Client 5: HD100 connected to Vizio VX37L |
#219
#220
On the power button issue, I didn't know there was a way to change the ir code that wakes up the system when using the MCE receiver. How do you configure that in Vista? thx mike
MCE remote driver for XP Home? | blade | Hardware Support | 25 | 02-17-2012 07:55 PM |
MCE remote transmitting keypresses twice | arnabbiswas | Hardware Support | 1 | 02-22-2007 10:55 AM |
mce remote conflict with xbox 360 | tsitalon1 | SageTV Beta Test Software | 1 | 12-01-2006 06:21 PM |
Do i have my remote control options understood | orangezero | Hardware Support | 6 | 05-05-2006 10:32 PM |
Can MCE Remote configuration be customized? | TwistedMelon | Hardware Support | 6 | 04-25-2006 08:45 PM |
